westcost1
posted on 23/5/08 at 02:13 PM |
speedo magnets?
Hello my build is coming along nicely but my biggest problem at the moment is how to fix and where to put the speedo magnets for the digi dash? all
the rest of it is working well lights temp petrol ect.
I was thinking ether get a ally ring turned up and attach it to the diff side of the diff to prop shaft flange with the sensor attached to the diff so
it moves with the ring (live axle).
Could this case inaccuracy in the reading as it is not turning at the same rate as the wheel? Because of the diff ratio.
Or drill holes in the flange of the rear break drum and fix the sensor through the back plate looks like it could work but will only reed accurately
in a straight line dose this matter for sva?
Thanks for your thoughts Nick
posted on 23/5/08 at 02:19 PM |
can you not buy or make a sensor that fits to the gearbox for speedo cable take off?
you can program the speedo to take into account diff ratios, number of magnets and tyre diameter - that is the least of your worries.
I fitted sensor inside the drum (english axle) and the magnet was in an aluminium disc pressed into one of the holes in the drive flange in core plug
style (this was for the bike speedo)
I later fitted a racetach speedo with a sender fitting to the gearbox speedo drive (easier said than done!) - you can buy the adapter from Burton
power to use a Ford electronic speedo sensor.
[Edited on 23/5/08 by 02GF74]
westcost1
posted on 23/5/08 at 02:27 PM |
have you got a link to the page on Burton power? cant find any thing on there at the moment
matt_claydon
posted on 23/5/08 at 02:31 PM |
Diff flange is fine, just adjust the 'distance per pulse' that you program into the speedo - divide the distance moved in one wheel
revolution by the diff ratio.
If anything it's slightly more accurate as there are more pulses in a given distance, but it's pretty negligible!
[Edited on 23/5/08 by matt_claydon]
posted on 23/5/08 at 02:36 PM |
search for "GBT9560" or speedo adaptor.
only £ 13 now .... sure they were £ 30 before ..... wouldn't have bothered making my own...
westcost1
posted on 23/5/08 at 02:44 PM |
good point matt hadnt thought about that so thats 1 for diff over drum
ok found it cheers so can you get a sensor from ford that will do away with the manets all together ?
Part No: REVT9-A Status: Available from stock.
Item Price: £12.72 Surcharge: £0.00 Price: £12.72
£14.95 (exc.Vat)
(inc.Vat)
Description: ELECTRONIC SPEEDO ADAPTOR: FORD GEARBOX
Other Info: ADAPTOR TO FIT ELECTRONIC SPEEDO SENDER TO SPEEDO DRIVE OUTPUT ON TYPE 9/ROCKET GEARBOX. M18x1.5 THREAD - SUITS MANY MAKES OF OE SENSORS
EG FORD, VAUXHALL, FIAT, VW, ETC. SENSOR AVAILABLE UNDER PART NO REVFSSImage deleted by owner
westcost1
posted on 23/5/08 at 02:54 PM |
off subject just been lookin at this
https://tickets.motorsportvision.co.uk/calendar/race-event-details.asp?ProductID=3575 looks fun worth taking a day of building to take misses out keep
her happy ok its not the beach or shoping lol
