Author: Subject: Ride height, ground clearance
edspurrier
posted on 24/5/08 at 03:06 PM Reply With Quote
Almost finished.... But not sure where to set the ride height or the front suspension. At the moment when the car's empty the track rod arms are level and the chassis is about 4r" off the ground - but thre;s only about 1 1/2 inches of clearance under the bellhousing. Short sump so plenty of room there.
Is that how it's supposed to be? Would have expedcted a bit more room for bumpy roads!
Ed
Paul (Notts)
posted on 24/5/08 at 03:27 PM Reply With Quote
My lowest point ( sump ) has 3-4 inches and I think that is too close at times.
If you try driving it on the road you will need a new bellhousing within a week!
Paul
blakep82
posted on 24/5/08 at 03:42 PM Reply With Quote
my car's going to end up being about 90mm (whatever that is in inches)
________________________
RazMan
posted on 24/5/08 at 03:57 PM Reply With Quote
You might need to rethink your engine mounts if you've only got 35mm under your bellhousing
Raz
posted on 24/5/08 at 06:00 PM Reply With Quote
75mm clearance is cutting it a bit fine.
90mm is what I run at the moment and I have to take it very carefully over speed bumps...
Rudy
posted on 26/5/08 at 06:04 AM Reply With Quote
I changes engine rubber supports with same taller, now sump is 75 mm from ground I am still not happy.
Sorry about my English
