Author: Subject: Part Built Locost - Ebay
neilj37
posted on 2/6/08 at 12:08 PM Reply With Quote
NTDWM
Interesting build and use of materials ??
Ebay Link
[Edited on 2/6/08 by neilj37]
mookaloid
posted on 2/6/08 at 12:11 PM Reply With Quote
Ah yes the Locust - ladder chassis and plywood body.
Probably not the best handling car out there
ash_hammond
posted on 2/6/08 at 12:23 PM Reply With Quote
At least the plywood body will be easy to keep in good condition - 20L of Cuprinol and your sorted for 5 years
.: www.mac1motorsports.co.uk | www.m1moc.com :.
mr henderson
posted on 2/6/08 at 12:26 PM Reply With Quote
I've not studied the Locust construction, but there is no inherent reason why a properly designed and made plywood body shouln't be very stiff, and at a reasonable weight.
John
r1_pete
posted on 2/6/08 at 12:34 PM Reply With Quote
You can just imagine the TV ad, with a fat bloke, a silly laugh, spraying his car.....
mookaloid
posted on 2/6/08 at 12:36 PM Reply With Quote
John
I think the key words there are 'properly designed' - The Locust body is just built on to the chassis with very little consideration for stiffness considerations.
viatron
posted on 2/6/08 at 02:53 PM Reply With Quote
having built one of these i can vouch for the fact that the body adds little or no rigidty to the chassis, not does it need too!! the bl**dy thing weighed a ton and would put the forth road bridge to shame. That said it was my first intro to kit cars and was a pleasant enough build with an ok end result, the handling was ok compared to cars of its day. the one nice thing was that the complete body build including ali sheeting only took 2 days.
bernmc
posted on 2/6/08 at 05:34 PM Reply With Quote
Locust? I thought they were called Morgans?
jacko
posted on 2/6/08 at 08:09 PM Reply With Quote
NO steel chassis and plywood top must be a CARAVAN
eccsmk
posted on 2/6/08 at 08:28 PM Reply With Quote
i wonder if a wooden locost would float?
wilkingj
posted on 3/6/08 at 08:08 AM Reply With Quote
Oh God... How misinformed you are
<Anorak>
Caravans are made on Galvanised steel (and some on Alluminium) chassis.
Since the early 1970's they have mostly been made of sheet alluminium bonded to a Polystyrene or (now) composite foam board with (usually) hardboard on the inside. This is relatively strong and very light.
Not really the best construction for a body like a Locost.
</Anorak>
Best Regards
Geoff
http://www.v8viento.co.uk
wilkingj
posted on 3/6/08 at 08:09 AM Reply With Quote
YES.... It would float straight to the bottom
Best Regards
Geoff
