omega0684
| posted on 6/6/08 at 09:38 PM |
vr sensor + trigger wheel set up
evening guys ,
just a quick question, as per previous posts regarding my megasquirt edis conversion, im a little confused regarding the vr sensor and trigger wheel
set up,
i've read some websites that say you should mount the sensor @ tooth 9 after the missing tooth when cyclinder 1 is at tdc, and others say you
should mount the sensor @ tooth 9 before the missing tooth,
so which is it?
p.s running pinto with clockwise crank rotation
DarrenW
| posted on 6/6/08 at 09:43 PM |
Tooth 9 is another way of saying 90 degrees. The aim is to tell the ECU 90 degrees before the engine gets to TDC. Its just a way of making sure the
ECU knows TDC is on its way. If it triggered at TDC the signal would reach the ECU after actual TDC - does that make any sense?
DarrenW
| posted on 6/6/08 at 09:46 PM |
You dont have to mount the VR sensor at 90 degrees before the TDC marker - this is not convenient. I think all i did was put engine at TDC, wind it
back to 90deg before, then find good place to put the sensor and align the missing tooth to the sensor.
RichardK
| posted on 6/6/08 at 09:48 PM |
Does this help mate ? TDC
R
Gallery updated 11/01/2011
omega0684
| posted on 6/6/08 at 10:08 PM |
where did you get that sensor bracket from? i could do with one of them. i had to make one but dont think its strong enough
| posted on 6/6/08 at 10:10 PM |
google is your frined.
The following graphic illustrates how the sensor position and missing tooth can vary relative to engine TDC- regardless of where the sensor is
mounted, the missing tooth must be positioned accordingly.
piccy is linky
RichardK
| posted on 6/6/08 at 10:20 PM |
I made it, this picture is a little clearer as to how it's put together.
Cheers Rich
[Edited on 6/6/08 by RichardK]
clairetoo
| posted on 6/6/08 at 10:31 PM |
Quite simply - at top dead , the missing tooth will be 90 degrees past the sensor - just be sure to read your engine rotation correctly
[Edited on 6/6/08 by clairetoo]
[Edited on 7/6/08 by clairetoo]
Its cuz I is blond , innit
Claire xx
Will weld for food......
rayward
| posted on 7/6/08 at 09:38 AM |
this is my setup on a pinto, with the engine at TDC (well just about, the centre of the VR should be in the centre of the tooth)
hth
Ray
