Author: Subject: Oil pressure gauge
philw
posted on 10/6/08 at 04:50 PM Reply With Quote
Oil pressure gauge
I have two wires for my oil pressure gauge that connect to the sender, when i connect them either way the gauge just shoots to max any ideas?
Marlon
posted on 10/6/08 at 04:54 PM Reply With Quote
is it the right sender for that brand of gauge?
john.
Band Anyone?
Linky to SWMBO 's band
Linky to Brother in laws band
MKoc 1081
philw
posted on 10/6/08 at 06:12 PM Reply With Quote
john.
It used to work, now i don't know why it won't
Must try harder
posted on 10/6/08 at 06:45 PM Reply With Quote
Are you sure you aren't connecting the gauge to the oil pressure switch? The symptoms would be exactly as you have observed...
philw
posted on 10/6/08 at 06:54 PM Reply With Quote
I'm going to sound like a right cock now, but i'm sure thats where they came from( it's been nearly a year)
Must try harder
drhunter
posted on 10/6/08 at 07:45 PM Reply With Quote
I don't suppose one wire is the signal and one is power for the light, with the body being the earth for both?
philw
posted on 10/6/08 at 08:07 PM Reply With Quote
Yeah, there are two pins one wire works the light and the other seems to be live, as soon as i attach it to either terminal or earth it to the casing the needle goes to max, when i start it it seems to read backwards,20psi
Must try harder
