Author: Subject: which starter motor
jamrogers
posted on 24/6/08 at 03:04 PM Reply With Quote
which starter motor
Hi guys i'm getting conflicting opinions on which starter motor to use when fitting a type 9 gerabox to a 2l zetec using standard clutch & flywheel some are saying lucas part LRS543 and others lucas part LRS707. can anyone confirm which it is? cheers jamie
http://www.jamstigeravon.blogspot.com
posted on 24/6/08 at 03:07 PM Reply With Quote
when you say standard clutch do you mean 2.0L or 1.8? MHO is you need the 1.8 flywheel for the clutch to fit and work in the type 9 bellhousing.
Sierra 1.8 CVH or DOHC starter works with the 1.8 zetec flywheel.
jamrogers
posted on 24/6/08 at 03:18 PM Reply With Quote
hi cooser, i've already fitted the engine and box to the car with the 2l flywheel and clutch and clutch works ok, so i'm not sure if that is correct, all i need is a starter
[Edited on 24/6/08 by jamrogers]
build diary http://jamstigeravon.blogspot.com/
YouTube
https://youtu.be/JwwwilUd5Zo
austin man
posted on 24/6/08 at 08:28 PM Reply With Quote
Have fitted both 2litre and 1.8 litre zetecs both used the Sierra 1.8 CVH / DOHC starter motors no problem.
You do need to modify the sump if you have not already done so. It needs a section cutting out to allow the starter to fit
jamrogers
posted on 25/6/08 at 09:43 AM Reply With Quote
Hi austin man, do u know whichclutch release bearing u used?
YouTube
Rudy
posted on 25/6/08 at 03:33 PM Reply With Quote
About release bearing :
http://www.locostbuilders.co.uk/viewthread.php?tid=89074
In my type9 / 1.8 zetec I used sierra starter motor . A couriosity: my starter motor is on the right and in Uk starter motor is on the left.
Sorry about my English
