Author: Subject: SVA and Interior Mirror
Alan_Thomas
posted on 9/12/03 at 11:14 AM Reply With Quote
SVA time is here and however many times I read the SVA regs on Interior mirror I don't get the answer to my question.
I am fitting O/S and N/S mirrors and understand the requirements for these but wonder if an interior mirror is required.
The regs state that if more than 15% of the vision thru the interior mirror is blocked then a N/S mirror must be fitted.
I have 'Hi Back' seats fitted and therefore can see very little from a mirror fitted to the top of the scuttle (no windscreen for SVA!) so have fitted a N/S mirror, but qustion is do I still have to fit a central mirror?
If it is required does anyone know where I can find an SVA compliant mirror to fit to the top of the scuttle?
posted on 9/12/03 at 12:13 PM Reply With Quote
I read it that an internal mirror is not required - that's the way I'm doing it anyway, as there's zero visibility from that mirror in my car.
If you haven't got the internal mirror for whatever reason, then you must have 2 external ones, as you say.
If you're close to the SVA, why not give them a ring? Seems they're pretty friendly, from what people have been saying here.
Northy
posted on 9/12/03 at 06:23 PM Reply With Quote
I rung the Beverly test centre (where mine will be going for SVA) about the mirror regs, and he told me that I would need a centre mirror, and would fail without one. Even if I couldn't see anything out of it!
Oh well, probably best to ring them.
Graham
paulf
posted on 9/12/03 at 09:54 PM Reply With Quote
Nottingham also told me the same. The only time a centre mirror is not required is if nothing at all could be seen through it as in a van for instance, in this case a passenger side mirror must be fitted.
If the required visibilty can be seen through the drivers and centre mirror then no passenger mirror is required.
Paul.
Chris Leonard
posted on 10/12/03 at 12:50 PM Reply With Quote
You can get a £4.00 rubber suction mirror from Halfords - why not just stick one of them on and take it off afterwards
Chris
Mark H
posted on 10/12/03 at 01:07 PM Reply With Quote
I think it needs to be more secure than a suction cup, Chris. Although mine passed with double sided sticker.
Mark Harrison and
Q986 KCP back from the dead...
