Author: Subject: biest brake pedal
indyian
posted on 17/7/08 at 12:23 PM Reply With Quote
biest brake pedal
hi all i seen somewon mentioning about putting rollpins somewere on the pedel setup for the sva test could somewon explain were and what for , a diagram or pic would be good
many thanks ian
Mr Whippy
posted on 17/7/08 at 12:27 PM Reply With Quote
hmm never heard of that type before
posted on 17/7/08 at 12:32 PM Reply With Quote
Bias bar setups have to be locked ie roll p inned to prevent adjustment.
its specified in the SVA manual.
I wound mine up to near maximum front bias, the tester did all the tests then asked me to pin it...
AdamR
posted on 17/7/08 at 12:33 PM Reply With Quote
This only applies if you're using a bias bar adjustable setup with two master cylinders. You have to permanently fix the position of the bias bar for SVA - the easiest way usifng rollpin through the adjustment nuts and bias bar.
HTH
brynhamlet
posted on 17/7/08 at 01:49 PM Reply With Quote
At Nottingham, when I took my car they were mandatory. I had put a split pin through the nut at one end and put a lock nut on the other end. But to no avail, it has to be roll pins. I’d challenge anybody to remove a split pin and locknut whilst the car is moving!
The saving fact was the tester found a battery drill, I had the drills, and the HVG garage next to the test centre gave me the roll pins.
Oh and I'm pretty sure there is a pic on here somewhere
[Edited on 17/7/08 by brynhamlet]
bassett
posted on 17/7/08 at 05:10 PM Reply With Quote
I didnt realise the bar had to be locked, a picture would help me out too.
[Edited on 17/7/08 by bassett]
