Northy
posted on 22/12/03 at 09:58 PM |
How do I adjust a Filter King pressure regulator?
Well as it says really. I bought it second hand, and so don't have any distructions
Anyone know?
Graham
greggors84
posted on 22/12/03 at 10:44 PM |
I have one i got with the engine and it has a bit you can twist on the top, i guess this has something to do with it. Im not sure how it adjusts it,
but would be interested to find out.
Chris
The Magnificent 7!
Northy
posted on 23/12/03 at 08:52 PM |
Someone must know
It looks like this:
Graham
RichyMkIndy
posted on 24/12/03 at 11:34 AM |
so can you effectively "turn up the boost" by just fueling the carbs more?
Stu16v
posted on 24/12/03 at 06:45 PM |
No mate, you could however cause the carbs to flood, cause fires (esp. Xflow owners, whose dizzy sits handily under a dripping carb ), and
prematurely wear the cylinder bores out, because the excess fuel will wash any lubricating oil away.
Fuel doesnt equal more power, not unless you can get more air in
greggors84
posted on 25/12/03 at 12:47 AM |
Right rich! im not lettin u tune the carbs!
Chris
The Magnificent 7!
Surrey Dave
posted on 25/12/03 at 11:33 AM |
Filter King Adjustment
When I used these on my Karts in the 70'/80's we used to adjust them with the screw (which is under the domed nut) and lock nut .
You may be able to set them with a fuel pressure gauge if you no what pressure you are after.
But the way we did it was to connect the outlet to a piece of plastic pipe that ran vertically up a piece of wood.
You can then set the pressure by the height at which the fuel will stop pumping at i.e 27" of head (sorry) may equal 1 lb fuel pressure.
This should be very accurate.
You'll have to research the actual figures, as I cant remember,they will differ for different liquids ,water ,petrol etc.
I can remember we set the regulator on the kart to 44" !!!!! we used these to stop the carb flooding due to vibration opening the needle
valve.
Take me out and shoot me I'm answering posts on Xmas Day!!!!!!!!!!!
