Author: Subject: Wtd 4 of M10 x 1mm Nuts
r1_pete
posted on 18/8/08 at 05:55 PM Reply With Quote
Anyone got 4 M10 x 1mm pitch nuts I can buy, or know a low volume supplier. Plenty of 1.25mm pitch about but not extra fine.
Cheers.
Pete.
COREdevelopments
posted on 18/8/08 at 06:07 PM Reply With Quote
what you need them for? brake bulkhead fittings? if so i just used m8 nuts drilled out and tapped with m10x1. easy and free if you got a m10x1 tap that is.
Rob
posted on 18/8/08 at 06:25 PM Reply With Quote
For this kind of occasion I either go to Ebay or Namrick
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160207690835
http://www.namrick.co.uk/browse.asp?PCID=9
r1_pete
posted on 18/8/08 at 06:47 PM Reply With Quote
Rob
They're for the pin top fittings on Bilstien shocks, they have a lock nut arrangement to set the cushions at the right compresion, those on ebay will do, just trying to leave ebay alone... has its uses I guess.
Cheers.
Pete.
[Edited on 18/8/08 by r1_pete]
antonyg
posted on 18/8/08 at 07:46 PM Reply With Quote
Hi, i think i have some in the garage that i dont need will check and let you know
cheers Antony
turbodisplay
posted on 18/8/08 at 10:11 PM Reply With Quote
Ford sell them for the brake fittings
Darren
antonyg
posted on 19/8/08 at 07:11 AM Reply With Quote
yes, got about 8 spare how many do you want
Antony
r1_pete
posted on 19/8/08 at 06:42 PM Reply With Quote
Thank you for the responses chaps, I'm sorted with the nuts now.
Cheers.
Pete.
