New Topic New Reply
Author: Subject: fog light quetion
indyian
posted on 25/8/08 at 05:45 PM Reply With Quote
fog light quetion
hi all can anyone tell me if the fog switch is ok to work when the sde lights are on or can it only work when the main beem /dipped are on for sva many thanks ian
adithorp
posted on 25/8/08 at 06:01 PM Reply With Quote
The only thing required of the fog light are to do with brightness, angles of visability, that its 10cm from the brake lights , the lens is vertical and that it has a warning light on the dash.
No requirement as to what other lights its on with. Tin tops used to only work with dip beam only but now many work with dip and main beam.
adrian
http://jpsc.org.uk/forum/
mackei23b
posted on 25/8/08 at 06:05 PM Reply With Quote
The fog light can work with any combination for the SVA, you just needdto make sure you have a tell tale / warning light on the dash.
cheers
Ian
New Topic New Reply
