Author: Subject: floor mounted accelerator design ideas
rumplitter
posted on 28/8/08 at 09:39 AM Reply With Quote
I've still not made my accelerator pedal but have plenty of ideas! I know that i definitely don't want top hung, or to have the cable/spring protruding above the chassis as I've other ideas for the area between the chassis and the bodywork.
I've attached a couple of sketches for comments! Rescued attachment floor mounted accelerator pedal.jpg
http://www.locostbuilders.co.uk/upload/MiniMojoProject.JPG
rumplitter
posted on 28/8/08 at 09:41 AM Reply With Quote
don't know how to attach multiple docs.
Paul TigerB6
posted on 28/8/08 at 09:50 AM Reply With Quote
I'm confused by those first two!! Is that the pivot point at the bottom?? If so whats the bracket / bar at the top??
I bought a floor mounted one from MK Sportscars (for £10, in the back pocket!! ). Think they are normally about £18
rumplitter
posted on 28/8/08 at 10:01 AM Reply With Quote
the bracket at the top is to take the accelerator cable.
novacaine
have you had a look at the accelerator pedal design in the haynes roadster book?
that looks like it would meet your requirements
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
rumplitter
posted on 28/8/08 at 10:08 AM Reply With Quote
no! not seen that!
Humbug
posted on 28/8/08 at 10:15 AM Reply With Quote
Just from a point of view of practicaility, I think 2 looks best:
1 has the cable attachment plate interfering with the pedal and 3 has a tail that would surely hit the floor when you press the pedal?
Slightly O/T, what (in general) is the thinking behind floor mounted pedals rather than top hung? I have always found that top hung pedals feel better because you can press them by pushing your whole leg rather than (at more extreme angles) pivoting your foot which can get quite tiring.
Paul TigerB6
posted on 28/8/08 at 10:40 AM Reply With Quote
Well 1 and 2 will mean pressing the pedal will mean you are pushing the cable. You want a pull on the cable dont you??
posted on 28/8/08 at 10:54 AM Reply With Quote
LOL = my thoughts exactly.
really 3 is the only option that will pull a cable unless you have some cunning rod arrangement.
Also think about perhaps making hte cable pull adjustable, if that is not done on the carbs i.e. the cable attachment point is adjustable to alter the amount of cable pulled as the lever is pressed.
rumplitter
posted on 28/8/08 at 12:04 PM Reply With Quote
they'll both be pulling! just depends on where you place the cable. (I have a long cable from complete car solutions, which is adjustable and long enough for either option!)
Paul TigerB6
posted on 28/8/08 at 12:24 PM Reply With Quote
So the engine is in the back then?? So the plan is to take the pedal straight back from alongside your foot??
[Edited on 28/8/08 by Paul TigerB6]
rumplitter
posted on 28/8/08 at 12:31 PM Reply With Quote
yep! Mid engine Sylva Mojo (mini shell)
