Author: Subject: Arghghg! Help!
joneh
posted on 29/8/08 at 07:22 PM Reply With Quote
Arghghg! Help!
In a fit of enthusiasm I've decided to replace my rear pads on my Vectra.
"Firmly twist the piston clockwise to retract"
My arse! I can't do it and I now haven't got a car!
Does anyone local to fareham have a brake caliper retraction tool? Or do Halfrauds sell them? The thing for compressing the piston.
P.S. Nice of the haynes manual to tell me I needed a 7mm Allen key. Sigh.
Jon
clairetoo
posted on 29/8/08 at 07:31 PM Reply With Quote
Pushing it back wont work with handbrake callipers - you need to `screw` it back in . There should be either a slot or a hexagon to help do this .
Its cuz I is blond , innit
Claire xx
Will weld for food......
Moorron
posted on 29/8/08 at 07:38 PM Reply With Quote
yep you got to wind it back in, only problem is the piston rotates and not the screw part so you think its winding round but it isnt. If this is the case you need to apply clamping pressure to it to help it stick allowing the screw part to rotate in and last time i did this on a friends car i used a g clamp and a nut under the head so i could get a spanner on it.
A right pain.
Sorry about my spelling, im an engineer and only work in numbers.
joneh
posted on 29/8/08 at 07:39 PM Reply With Quote
Yeah I've tried screwing it in with needle nose pliers but it wont move in.
I can turn it but it won't compress. Is there a technique other than brute force? Any trade secret?
smart51
posted on 29/8/08 at 07:41 PM Reply With Quote
Sierra rear calipers have slots cut in the edges. I made a tool out of angle iron with a piece cut out with a grinder.
Put the tool in the slots.
Push the piston in HARD whilst turning.
givemethebighammer
posted on 29/8/08 at 07:44 PM Reply With Quote
Did my sierra ones with the pin spanner that came with the angle grinder.
Add a G clamp for a bit of pressure ?
[Edited on 29/8/08 by givemethebighammer]
ahb
posted on 29/8/08 at 07:54 PM Reply With Quote
G Glitter's in your area and I think he needs a job!!!
Only joking.
Al
Hello!
John.Taylor
posted on 29/8/08 at 08:05 PM Reply With Quote
I used an angle grinder tool and brute force on my Sierra rears, same as givemethebighammer
Mark G
posted on 29/8/08 at 08:19 PM Reply With Quote
make sure you push them in at the same time as turning otherwise they won't go in.
t.j.
posted on 29/8/08 at 08:41 PM Reply With Quote
yep, without the right tool it will hard to get them back in.
tomgregory2000
posted on 29/8/08 at 09:11 PM Reply With Quote
vectras have a sep handbrake inside the rear disc hub so u should be able to just push the piston in with no turning
posted on 29/8/08 at 09:47 PM Reply With Quote
Perfect fit isn't it? LOL Good posting!!!
rodriguez
posted on 30/8/08 at 03:33 PM Reply With Quote
my vectra sri was the same as this! pain in the arse. I used a G-clamp 2 apply the pressure and turn it at the same time. my bros mk4 golf was the same but wouldnt go in with the G-clamp, bought the tool from hellfrauds, used it and the returned it the next day lol
get it lit
