Author: Subject: Anyone tell me how to use a timing belt tensioner??
eznfrank
posted on 7/9/08 at 07:24 PM Reply With Quote
I'm trying to figure out what appears to be a very simple timing belt tensioner but I can't figure out what to do with it and what goes where??
(other than use it for retrieving nuts dropped right under the car)
It's like this one
Mark G
posted on 7/9/08 at 07:46 PM Reply With Quote
there are many types, can you upload a photo of the one you have?
eznfrank
posted on 7/9/08 at 07:51 PM Reply With Quote
It's the one in the link above
Mansfield
posted on 7/9/08 at 07:53 PM Reply With Quote
I haven't seen one of those before, looks quite useful as long as you dont need to go through too great an angle to release the belt.
Mark G
posted on 7/9/08 at 07:56 PM Reply With Quote
OK, I get it, what car are you doing the belt on? Can you get a photo of the belt and tensioner?
Miks15
posted on 7/9/08 at 08:02 PM Reply With Quote
i might be completly wrong here but...
It says its used for spring loaded tensioners... so i assume ur tensioner is spring loaded.
SO put the thin socket on the end of the long stick thing, thread it down in the engine bay and put on the hexhead on the tensioner, then apply pressure as if you trying to tighten or loosen (depends which way it needs to go) a bolt. the rotational force will cause the spring to compress and slacken the belt?
Like i said i could be completly wrong but without seeing yours i cant be sure
davidwag
posted on 7/9/08 at 08:03 PM Reply With Quote
All that is, is a very long spanner to wind back a spring loaded automatic tensioner. Not really a tensioner at all. Should also work on the automatic tensioners on poly V belts too.
Mansfield
posted on 7/9/08 at 08:44 PM Reply With Quote
Originally posted by davidwag
Yes. It should really be called a detensioner.
owelly
posted on 8/9/08 at 09:25 AM Reply With Quote
The bit of kit is a Timing Belt Tensioner Tool Set. It is a tool for working with a timing belt tensioner. Not a thing to tension a timing belt if you see what I mean??
http://www.ppcmag.co.uk
posted on 8/9/08 at 09:26 AM Reply With Quote
Yup. Quite a few cars have auto-tensioners (or torque based tensioners). The old way of doing it was based upon centimetres of deflection over a fixed distance (ie see how taught the belt was).
eznfrank
posted on 8/9/08 at 12:05 PM Reply With Quote
Ah, I think I was overcomplicating it. I thought the two bars clipped together to kind of pivot or something. Essentially I guess it's not dissimilar to a breaker bar really.
Thanks.
posted on 11/9/08 at 01:06 PM Reply With Quote
The ones I have done you have to apply tension using the tool (against the spring) and then do up a clamp which keep the tension on the belt. There is usually a pointer you have to align with a fixed mark to set the correct tension.
