MautoK
posted on 16/9/08 at 05:40 PM |
Looking for a Sierra horn button disc and steering lock.
I've nearly finished my Indy and just remembered that I broke the plastic disc that sits under the horn push in the standard Sierra steering
wheel,
In more detail, it's a black plastic disc with a rim, two rectagular holes, brass contact and three split spigots to retain the moving part of
the horn push.
It's about 4 inches (103 mm) diameter and part number 87BB-13A925-AB.
On mine, all the spigots are broken.
Does anyone have a spare or surplus intact one of these or even the complete assembly that they could bear to part with?
I've also got a broken steering lock (as supplied with the donor!) so I'm looking for the upper casting assembly with a working steering
lock mechanism if anyone has a spare.
Donor was a 1989 2L Auto Estate, FWIW.
Please U2U and we can sort out remuneration, P&P, addresses, etc.
Thanks in advance!
Big_Al
posted on 16/9/08 at 07:59 PM |
May be able to help you. Will check what i have and send U2U sometime tomorrow.
Bigheppy
posted on 16/9/08 at 08:34 PM |
In a similar vain i'm looking for the indicator cancelling cam, the bit that sits under the steering wheel. Thanks neill
MautoK
posted on 19/9/08 at 08:05 PM |
Fixed the horn push using three self-tappers (OK, they're the spawn of the devil but perfect for this!)
