<<  1    2  >>
Author: Subject: Self centering....
Eggy
posted on 26/9/08 at 07:31 PM Reply With Quote
Self centering....
Ok, it's driving me mad!
I've read loads of posts, looked on the net, and asked at the Speed Trials. All with diferent answers - what's correct?
Is there a definate fix for this (raising the rack, using valve springs, over inflating tyres etc).
What's been done before that works??
Photo's would really help too!!!
Kev.
Paul TigerB6
posted on 26/9/08 at 07:37 PM Reply With Quote
trial and error seems to be a good starting point - see what works on your car!!
Start with a bit of toe out and see how that goes
blakep82
then a bit more castor
________________________
chrisg
posted on 26/9/08 at 07:45 PM Reply With Quote
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
blakep82
posted on 26/9/08 at 07:46 PM Reply With Quote
mmm worms on toast
jacko
posted on 26/9/08 at 07:56 PM Reply With Quote
What car you building ie MK / locost /MNR / it may help us help you
paulmw
posted on 26/9/08 at 08:38 PM Reply With Quote
I got really pi$$ed off with this when building my Indy. Most answers to the problem were either sarcarstic or wrong.
In the end I added some valve springs to the rack and on the SVA the steering would magically spring back.
....... step away from the soap box................
simonk
posted on 26/9/08 at 09:02 PM Reply With Quote
Some sensible tips would also be appreciated here also. Castor is the obvious one but that's set by the front end geometry for most of us. I can rotate the mushroom to drop the upright back a bit to get a little more trail and was planning some toe-out and 40lbs of tyre pressure. I have already juggled wishbone washers to move the bottom bone fully forward and the top one fully back and on my exploratory drives down the lane it's still not great.
Any other practical tips would be very welcome.
Eggy
posted on 26/9/08 at 09:25 PM Reply With Quote
I've heard about this but can't get my head around it, anyone got some pictures?
NeilP
posted on 26/9/08 at 09:45 PM Reply With Quote
Some trailing hub helped mine a fair bit after shuffling the wishbones as far as washers would allow - From my experience, toe in/out and tyre pressure seemed to have a very limited effect...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
whitestu
posted on 26/9/08 at 09:48 PM Reply With Quote
Valve springs in the rack were the only things that made a difference on my Indy as well.
I think the proper fix is to make new top wishbones with more castor.
Stu
mark chandler
posted on 26/9/08 at 11:14 PM Reply With Quote
Caster is the key, look at any motorbike, the forks always lean backwards, the principle is exactly the same.
So twiddle the mushroom, pack the bottom bones forward with washers and the top bones backwards or better still make some new top ones, they are easy to make, you just need a bit of board and some nails to make a jig.
Regards Mark
zetec7
posted on 27/9/08 at 04:09 AM Reply With Quote
Or, maybe it's possible to cut the upper a-arm mounts off and move them rearward, ideally 1" or so. We designed our a-arm mounts to be adjustable for caster angle - we can add as much as another 1" rearward displacement of the upper 'bones.
And, yes, caster is the ONLY right way to add self-centering. Toe-out = twitchy steering, toe-in = rapid tyre wear & rapid onset of understeer in corners.
As for valve springs in the steering rack...well, I suppose it works, but it strikes me as fundamentally wrong for some reason...probably because self-centering is suppose to occur automatically as a result of good suspension design and adjustment. I suppose you could use bungy cords on the steering column...
http://www.freewebs.com/zetec7/
posted on 27/9/08 at 07:00 AM Reply With Quote
The fundamental problem is that nearly all the kit manufacturers are selling chassis & front suspension with a design flaw built in - for road use anyway.
The original design with minimal castor is fine for the race track, where self-centering isn't a major concern and the lightness of the steering is a bonus. For the road a lot more castor needs to be built into the design, and no amount of fiddling about can rectify its omission. People worry about it for the SVA, when in reality it's essential for comfortable and safe road driving.
The fix is really easy for the kit manufacturers - make a minor adjustment to the top wishbone jig, so that the top pivot is about 22 - 24mm behind the lower pivot - and a lot of people will be a lot happier.
Until builders put a significant amount of pressure on the chassis makers, the issue will continue to come up here, and the silly answers will continue, as everyone here who's built a commercial kit knows that the fundamental error is built-in and can't be fixed by half-arsed and potentially dangerous bodges.
And that's my 2p's worth for the morning!
[Edited on 27/9/08 by David Jenkins]
flak monkey
posted on 27/9/08 at 07:24 AM Reply With Quote
My GTS self centres brilliantly. Not sure what the offset is on the top wishbones, dont think I ever measured it.
Front geometry is set to the same as the caterham set up. Lots of camber and very little toe. Sticks brilliantly into the corners and get full tread contact on the tyres running 17psi per corner.
Sera
http://www.motosera.com
posted on 27/9/08 at 07:59 AM Reply With Quote
Rotating the Mushrooms will have no effect on caster
Mole
posted on 27/9/08 at 08:03 AM Reply With Quote
Anyone would think you'd mentioned that before.
Increasing the king pin inclination will help ----- this can be done by rotating the mushrooms.
whitestu
posted on 27/9/08 at 09:10 AM Reply With Quote
I got next to no difference in self centring however I adjusted mushrooms and toe.
I agree the bones should be made differently, and will be trying this next.
I used springs for SVA which worked [they also limit lock which helps to prevent brake pipes fouling as well], but I took them off straight after.
They are a bodge and I'm surprised MK recommend it [which they did to me when I phoned up for help].
I'm sure someone could make a few quid if they started selling modified top bones. as most people who buy kits do so cos they don't want to start making chassis bits.
Stu
t.j.
posted on 27/9/08 at 06:32 PM Reply With Quote
you don't have to scream...
My caster is adjustable by moving the mushrooms/shims in the brackets in the lower and upper wishbones.
So pictures could be helpfull, to understand each other.
I want to know which mushroom is pointing at? KPI adjustable?
[Edited on 27/9/08 by t.j.]
mad-butcher
posted on 27/9/08 at 07:43 PM Reply With Quote
Just a couple of observations, not that I know what the F**K I'm talking about.
1. By rotating the mushrooms would this not make the problem worse. my nut is a the front meaning that the upright is fully adjusted to rear, if I rotate the mushroom it will push the upright forward, surely the opposite effect to what we are looking for.
2. if by moving the adjustment towards the the rear of car. by moving brackets rearwards or by remaking the top wishbone, is this not going to put too much strain on the ball joints.. my bottom one alresdy looks at a frightning angle.
3. the use of springs to induce self centering seems a bit weird to me, my transit, my 7.5 ton works vehicle and the wifes pajero all self centre from very little movement of the steering wheel, so what benefit do springs serve, or are we saying that for the sva they only test for self centering on full lock.. (a position of the steering that I think most people would rarely use) when are you ever on full lock in normal motorway driving.
Tony
[Edited on 27/9/08 by mad-butcher]
simonk
posted on 27/9/08 at 10:21 PM Reply With Quote
Agree, the ball joint on my mushrooms is currently directly adjacent to the wheel - if yours if fully forward then whatever you do will reduce trail. I will try moving the mushroom round to push the upright back as far as possible.
To clear up the discussion and agree with Triton adjusting the mushroom has no effect on caster or king pin inclination. All you can do with the mushroom is add or reduce trail (how far the contact patch is behind the point where a line drawn through the upper and lower pivot hits the ground) by moving the axle position in relation to the line described above. Increasing caster angle adds trail in addition to adding to the jacking effect of adding lock.
I won't be getting new top bones made by next SVA date so will be adding max trail (with the mushrooms) and will be upping the tyre pressures. Will let you know what happens.
Simon
posted on 28/9/08 at 11:27 AM Reply With Quote
It's a total bodge to get the car through the SVA.
t.j.
posted on 28/9/08 at 07:22 PM Reply With Quote
Simon
I don't know what, but you can increase your caster by moving the upper wishbone to the rear and the lower wishbone to the front.
wishbones seen from above
[Edited on 28/9/08 by t.j.]
posted on 28/9/08 at 09:17 PM Reply With Quote
An alternative would be for the chassis builder to fit extra-wide top pivot points - the builder could use washers or spacers to put the wishbones precisely where he/she wants them.
So, as I said earlier, the kit makers could remake their top wishbone jig, or the pivot point jig, or the shape of the pivot points, to permanently solve the self-centering problem. None of these are hard or big jobs.
So why don't they?
<<  1    2  >>
