tegwin
posted on 14/10/08 at 12:53 PM |
How flexible is bodyfiller?
Basically as title.... How flexible is bodyfiller?...If I put it on a thin fibreglass body panel will it stay inplace or just crack of as soon as the
panel flexes?....
What is the best filler to use to fill holes, both interms of stickyness and finish?
www.verticalhorizonsmedia.tv
Mr Whippy
posted on 14/10/08 at 12:58 PM |
I'd recommend you use this stuff, and then put the thinnest skim of filler over it or use a filler primer. Extremely strong and won't
crack or fall off.
Used it once to fill a dent in a friends car door, years later when the car got written off, we took a hammer to it and pounded the crap out the door
to see if the filler would come of, it didn't and we practically turned the door inside out .
[Edited on 14/10/08 by Mr Whippy]
r1_pete
posted on 14/10/08 at 02:55 PM |
It depends, if you want to get it off something then you can bend it in two and it wont crack, but you can bet on your well prepared job it will
crack.
As Mr W says P40 is pretty good stuff, I've recently tried Isopon Metalik, very pleased with it you can even wet flat it and it doesn't
absorb the water like ordinary fillers do. I used it on an MGC bonnet, needed about 2mm over a massive area and its worked really well, and the bonnet
flexes as it would in the raw.....
[Edited on 14/10/08 by r1_pete]
hillbillyracer
posted on 14/10/08 at 06:46 PM |
How big is the hole you're going to fill? I removed the ariels from the roof on my ex-AA VW van leaving 4 holes between 25 & 40mm. I tapped
the edges of the holes low a couple of mm with a ball-pein hammer & took the paint off around it with a soft disc in my 4 1/2" grinder. I
used bridging filler (ready mixed fibreglass resin & strands) & once that was set I used conventional bodyfiller to make it perfect.
I could have welded the holes up but reckoned it'd cause distortion & ordinary bodyfiller on it's own would have cracked I think.
If you're using it on a fibreglass panel then it'll bond with the panel like it was all the original material.
It's not so good to work with as normal bodyfiller & takes much longer to properly cure though.
tegwin
posted on 14/10/08 at 09:08 PM |
The hole.....is about 70cm x 45cm
I have layed up a 2mm thick fibreglass sheet which I am going to bond to the inside of the roof....
On that I can lay more fibreglass to "fill" the hole in the roof to bring it up almost level with the final roofline....then fill the
rest...
Its just going to be a pain in the arse sanding it down to the correct curve.....its a seriously awkward shape!
