New Topic New Reply
Author: Subject: exhaust manifold close to chassis (3mm)
rumplitter
posted on 20/10/08 at 08:06 AM Reply With Quote
I've altered my exhaust manifold to fit but it is still very close to the chassis approximately 3mm. How do i protect the chassis from heat?
The chassis is about to be shot-blasted and powder-coated. Rescued attachment 20_10_08 035.jpg
http://www.locostbuilders.co.uk/upload/MiniMojoProject.JPG
maartenromijn
posted on 20/10/08 at 08:22 AM Reply With Quote
What about the engine moving in the cradle?
I think I would use a vice to dent the pipe a bit. I do know this will be bad for the flow in the pipe. Maybe use some kind of reflecting tape and a lot of air flow to protect the chassis.
BLOG: http://thunderroad-super7.blogspot.com/
posted on 20/10/08 at 08:54 AM Reply With Quote
^^^ wot he said. isn't the engine gonna move?
What I would do is tack welda bar above the rail, cut the rail out under the exaust pipe and weld another slighlty longer rail below and maybe a gusset or two.
unless the clearance (the width of the rail) is an issue, that would be my suggestion.
andylancaster3000
posted on 20/10/08 at 09:37 AM Reply With Quote
Not only movement of the engine but don't under estimate thermal expansion as well, you'd probably be suprised by how much it will move. Our system lengthens something in the order of 10-15mm, admitadly over a longer run.
[Edited on 20/10/08 by andylancaster3000]
rumplitter
posted on 20/10/08 at 10:45 AM Reply With Quote
point taken!
I can cut the pipe further back, will 10mm clearance be enough or do i need more?
flak monkey
posted on 20/10/08 at 12:05 PM Reply With Quote
If your engine is rigid mounted, which I am guessing it is if its a bike engine then you only need enough space for thermal expansion of the exhaust, which will be 2 or 3mm on a stainless system.
10mm is going to be more than adequate.
Sera
http://www.motosera.com
New Topic New Reply
