DarrenW
posted on 24/10/08 at 03:30 PM |
Any medical experts - Tramadol
Ive just been prescribed Tramadol 50mg as a pain killer for my own going pain from whiplash. Ive been alerted that these tablets can be addictive and
care should be exercised taking them. Im really cautious about tablets. Can anyone confirm if they are OK or should i be wary?
Ive been told to take 1 or 2 tablets 4 times a day when needed. Im planning on trying 1 tablet 3 times a day initially and topping up with paracetamol
(i was told taking paracetamol is OK).
Mr Whippy
posted on 24/10/08 at 03:40 PM |
do you gamble alot? addicted to bingo?
then you could be at risk
chrisg
posted on 24/10/08 at 03:41 PM |
I've been taking them for a few months without problems
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
austin man
posted on 24/10/08 at 03:44 PM |
I have taken tramadol not addicted, its like anything if you start to rely on them then they will be needed that is why the doc has prescribed as and
when required. It is sometimes important that you do actually feel the pain as the painkillers will give you a false sense of well being . Best to
take only when needed when I first took them I felt as though I was floating I usually take codeine based or Tylex for my back problem the Tramadol is
a step up.
Paul TigerB6
posted on 24/10/08 at 03:47 PM |
But you were only prescribed them for a week..................
A1
posted on 24/10/08 at 04:00 PM |
just go with what the doctor said...i think they can be addictive, a girl at college od'd on them, was hallucinating and everything...
Paul TigerB6
posted on 24/10/08 at 04:06 PM |
Darren, you should take them then....... you never know, your Pinto engine might start to perform like a bike engine!!
Macbeast
posted on 24/10/08 at 04:10 PM |
With respect to everybody on here - isn't your doctor likely to be more expert than us ? Why go to doctor and then ignore his advice?
I would suggest don't mix them (topping up with ... )
Probably most important instruction is "when needed"
bob
posted on 24/10/08 at 04:33 PM |
My wife has been taking tramadol for a few months now, she also was concerned about any side effects and doesnt take the full prescribed dosage. She
takes one every morning with breakfast and another in the evening if needed.
She was advised that they can reduce your appetite for food which is probably fantastic news for chrisg
MikeR
posted on 24/10/08 at 04:34 PM |
Ignore doctors - they know sod all about drugs. Talk to your pharmacist - they know everything (in theory) about drugs.
I do this for a living.
Now, tramadol, its 50mg which is the weakest formulation (the others 100 and 150).
I was going to type out lots of stuff about do and don't - but yoru best bet is to just google it. Try going for the BNF (not sure if
you'll have access).
But - avoid alcohol, may cause drowsiness, may cause dependence (not sure without looking up more over what time), potential for withdrawl. I think
the dependance is long term - but as i said i haven't looked up, just quickly referenced the software we write for pharmacy. Honestly the
information will be on teh web.
In fact, here you go - its good enough for what you want,
http://en.wikipedia.org/wiki/Tramadol
slimtater
posted on 24/10/08 at 04:48 PM |
This is a fairly low dose analgesia when used in oral format. It can be used IM or IV as an alternative to Morphine and this is where you are more
likely to see adverse effects.
mads
posted on 24/10/08 at 05:17 PM |
Take them as prescribed i.e. 1-2 tablets four times a day, when required. Only take them when you find that your regular analgesia i.e. paracetamol
isnt sufficient to control your pain. Yes, one of the side-effects can be dependence, but for the condition you are prescribed them, you are not going
to be on them long enough for that to occur. I've taken them myself for back and tooth pain and I'm not addicted to them.
The more common side-effects you should note are: increased drowsiness (especially with alcohol), some people complain of hallucinations or feeling
zonked out, constipation (though this is likely than codeine).
If you are still concerned, drop me a U2U - i'm a pharmacist.
[Edited on 24/10/08 by mads]
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in
sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
omega0684
posted on 24/10/08 at 05:36 PM |
Tramadol is an opiod (an opiate)- that is why its addictive, what else do you know is an opiod/opiate -->Heroin!
this may help
Mechanism of action
The mode of action of tramadol has yet to be fully understood, but it is believed to work through modulation of the noradrenergic and serotonergic
systems in addition to its mild agonism of the μ-opioid receptor. The contribution of non-opioid activity is demonstrated by the analgesic
effects of tramadol not being fully antagonised by the μ-opioid receptor antagonist naloxone.
Tramadol is marketed as a racemic mixture with a weak affinity for the μ-opioid receptor (approximately 1/6000th that of morphine; Gutstein
& Akil, 2006). The (+)-enantiomer is approximately four times more potent than the (-)-enantiomer in terms of μ-opioid receptor affinity
and 5-HT reuptake, whereas the (-)-enantiomer is responsible for noradrenaline reuptake effects (Shipton, 2000). These actions appear to produce a
synergistic analgesic effect, with (+)-tramadol exhibiting 10-fold higher analgesic activity than (-)-tramadol (Goeringer et al., 1997).
The serotonergic modulating properties of tramadol mean that it has the potential to interact with other serotonergic agents. There is an increased
risk of serotonin syndrome when tramadol is taken in combination with serotonin reuptake inhibitors (e.g. SSRIs) or with use of a light box, since
these agents not only potentiate the effect of 5-HT but also inhibit tramadol metabolism. Tramadol is also thought to have some NMDA-type antagonist
effects which has given it a potential application in neuropathic pain states.
24vseven
posted on 24/10/08 at 05:43 PM |
i take them for knee pain as required no problems with them at all been on them on and off for 2 years now no problems when the dosage ends
i think like most things its down to the person tho as mentioned befor i dont think there will be a problem short term
[Edited on 24/10/08 by 24vseven]
bigpig
posted on 24/10/08 at 06:21 PM |
Yeah I've heard excessive doses can cause paranoid nightmares
DarrenW
posted on 24/10/08 at 07:22 PM |
Thanks for replies. I wasnt asking ref if i have been prescribed correctly, more that i want to know if there are any isues with taking them.
My mother in law was prescribed them recently. She works in Boots and knows the pharmacists, they told her to be careul with them and mentioned that
druggies like them. Iam anti-drugs in that way so have been a bit concerned. Some websites mention the withdrawal can be unpleasant, tbh i dont
particularly want to find out.
It does however sound like what im using them for should be OK. Ive read into the 'when needed' bit to mean that i dont have to take the
full dose each and every day, instead to reserve them for when the neck and back pain needs the edge knocking off.
I can remember when i got my tonsils taken out 2 years ago, i got into a bit o strife with the pain. Doctor gave me an injection that not only took
the pain away but also left me feeling rather nice Ive only had 3 Tramadols so far but have felt a bit like that (not as bad). I suppose seeing as i
cant drink with the i might as well enjoy them - it is Friday neet after all
DarrenW
posted on 24/10/08 at 07:23 PM |
Very funny That made me chuckle.
MikeR
posted on 24/10/08 at 07:28 PM |
quote: Originally posted by mads
i'm a pharmacist.
Sorry for the thread hijack, got to ask, who do you work for / are you locum or an independent?
Lets just say professional curiosity
And if you have anything to do with link I REALLY can't help
Paul TigerB6
Glad it was taken fully as intended. Cant beat a bit of light-hearted banter can you. Its amazing how many threads you can get the BEC vs CEC debate
into if you really try - even if its a totally pointless debate!!
DarrenW
posted on 24/10/08 at 07:32 PM |
Its a good job i can take a joke, the ne7ers lot give me a lot of stick for the ole pinto. It does its job though.
Its about time someone fitted a pinto into a bike - now that would be a talking point. Personally id be asking if they had been on the Tramadol
though
DarrenW
posted on 24/10/08 at 07:34 PM |
i'm a pharmacist.
Dont worry about hijack.
That last bit went straight over my head.
chrisg
posted on 24/10/08 at 07:43 PM |
I find they level me out when I'm coming down off heroin..... er ....I mean wurther's originals.
Chris
D Beddows
posted on 24/10/08 at 08:01 PM |
Errrr be wary - Mrs Beddows has fibromyalgia and was prescribed these... she was told there was no addiction problem and they worked really well it
has to be said.....but a few weeks ago she had a seriously bad couple of weeks coming off them once she figured out she had become addicted
DarrenW
posted on 24/10/08 at 08:11 PM |
Sorry to hear that Im hoping i dont find out what that is like.
How do you know when you become addicted to something? For me id imagine its when i remind myself constantly that its time for another. Normally i
forget when to take tablets and wonder why im hurting.
D Beddows
posted on 24/10/08 at 08:52 PM |
She put 2 and 2 together when she realised that she if she forgot to take them of an evening she felt like absolute cr*p until she took another one -
took a while because you think it's something you're eating or drinking etc etc
[Edited on 24/10/08 by D Beddows]
