Author: Subject: MASTER CYLINDER DIAMETER
jamie1107
posted on 25/10/08 at 12:01 PM Reply With Quote
hi
does anyone know the formula for working out what master cylinder sizes to use for brake and clutch systems in relation to the size of the calipers wheel cylinders and slave cylinders
i cant seem to find the info anywhere but what i want to achieve is a twin cylinder non servo set up which is very sensitive due to loss of power in my legs and basically the same with the clutch and i wondered if there was a magic sum i could work from
i realise i need to take into account the leverage from the peddles to so im thinking this could get complicated but hey building a car was never going to be easy lol
thanks guys
stevec
posted on 25/10/08 at 12:42 PM Reply With Quote
Is This any help.
Steve.
posted on 25/10/08 at 03:43 PM Reply With Quote
If you are using a balance bar setup just use 0.675" cylinders on both circuits. If when you find the balance bar is screwed too far too one side when you try the brakes (very unlikely) then change the side which is over braked to a 0.7" cylinder.
The simply rule is
Smaller master cylinder = more hydraulic pressure = less pedal effort.
[Edited on 25/10/08 by britishtrident]
Alan B
posted on 25/10/08 at 03:45 PM Reply With Quote
Or perhaps the more readily available 0.625" cylinders would work too....
posted on 25/10/08 at 04:03 PM Reply With Quote
your eyes are better than my typing
