Alez
| posted on 30/10/08 at 02:59 PM |
Marlin Sporster chassis
http://www.marlinsportscars.co.uk/sportster/
Does anyone have any pics of it? Or has anyone seen it? I'd like to learn if it's a modern proper space frame or rather a more outdated
design. I like the looks of this car and I'm getting keen on the idea of buying one and putting something idiotic inside, like a Viper engine or
something.
[Edited on 30/10/08 by Alez]
m8kwr
| posted on 30/10/08 at 03:04 PM |
this site seemed to have a lot of photo of a build, with a BMW engine..
Link
Mr Whippy
| posted on 30/10/08 at 03:08 PM |
same idea as their earlier cars
Alez
| posted on 30/10/08 at 03:22 PM |
Then no It spoils all the fun
mr henderson
| posted on 30/10/08 at 04:12 PM |
There's nothing wrong with the Marlin chassis, it's a tried and tested design, and it allows for doors as well.
John
D Beddows
| posted on 30/10/08 at 04:23 PM |
As Mr Henderson says there's nothing realy wrong with that chassis and if you're looking to put a huge engine in it I would say its
probably actualy more suitable than a 'modern' spaceframe. I believe the one of the factory demonstrators has a BMW M Power engine btw.
Modern sportscars don't have spceframes anyway - your Lotus elise for example is a glorified ladderframe chassis after all.....
Chippy
| posted on 30/10/08 at 04:35 PM |
If the chassis is anything like the old Marlin Roadster, which it does seem to be, then it's a well designed piece of kit. The roadster handles
very well, so can't see that this one would be much different. Cheers Ray
[Edited on 30-10-08 by Chippy]
iank
| posted on 30/10/08 at 04:46 PM |
Only downside with the design is it's a bit heavier than a spaceframe, but marlins, at least the older designs, are used a lot for classic
trials so their strength is undeniable.
Anonymous
Mr Whippy
| posted on 30/10/08 at 04:47 PM |
indeed, the original car was so stiff that the windscreen surround served as the roll bar
cymtriks
| posted on 30/10/08 at 11:18 PM |
Trawl back far enough here, and on other forums, and you'll find some lively debates on "ladder frames VS spaceframes" prompted by
my comments.
Most spaceframes are not actually anywhere near as stiff as their creators would like you to believe. Most of them lack the correct triangulation and
a lot have lots of reinforcement in the wrong places.
Even if you get a spaceframe right then the actual weight saving for a road car for the same stiffness is probably less than ten percent and with a
good ladder frame and some design compromises necessary to make the thing work may be around five.
Now look at the advantages of a ladder frame. Simpler, cheaper, easier to make, easier to get in and out of, better access for the engine and less
restrictions on engine layout (intake and exhaust).
The Marlin is a good design. The main chassis members are, IIRC, made of thinner steel than most ladder frames and it also use stressed footwells,
floor and tunnel areas. It uses its weight better than a lot of ladder frames do, which often rely on very heavy main tubes, and probably better than
a lot of spaceframes as well.
Alez
| posted on 31/10/08 at 11:50 AM |
Thanks Gents I'm not seduced by ladderframes or poorly designed spaceframes, so I'll think of something else.
While on the topic of chassis and stiffness, I like very much the idea the GTM guys embraced quite a few years ago already (composite monocoque). The
KTM X-Bow uses a similar thing I think. But that's a different story altogether
procomp
| posted on 3/11/08 at 09:56 AM |
Hi.
It was the front suspension that was being debated recently mind not the chassis.
Link HERE to the recall regarding lower front
suspension arms.
Cheers Matt
