Author: Subject: SVA IVA squabs, backrests and headrests?
rumplitter
posted on 31/10/08 at 08:45 AM Reply With Quote
I've got a modified Sylva Mojo chassis, I've already bought the squabs, backrests as the Sylva design. I presume they'll need restraining somehow? Can i just Velcro them in?
http://www.locostbuilders.co.uk/upload/MiniMojoProject.JPG
posted on 31/10/08 at 08:48 AM Reply With Quote
They need to be secured for SVA so they don't move in a crash.
A bit open to interpretation I suspect for the tester.
Sure some Sylva owner will be along soon to clarify.
matt_claydon
posted on 31/10/08 at 09:17 AM Reply With Quote
Head restraint requirements for IVA:
6. A system of head restraint must be fitted on every outboard front seat.
7. For outboard front seats the height of the top of the head restraint above the
H point must be at least 800mm.
8. Where optional headrests are fitted to seats other than outboard front seats,
the height of the top of the head restraint above the H point must be at least
750mm taking into account notes 5 and 6.
9. The head restraint must be at least 85 mm wide each side
of the vertical centre line of the seat and at least 100mm high.
10. The head restraint must be securely attached to the seat.
11. The head restraint must not have any roughness or sharp edges likely to
increase the risk of severity of injury.
12. The padding of the head restraint must be sufficient so as to prevent any
contact by a head with any of the internal hard parts of the head restraint.
If you see what happens to a neck in a rear impact without head restraints you won't think twice about the need to fit them!
[Edited on 31/10/08 by matt_claydon]
rumplitter
posted on 31/10/08 at 09:40 AM Reply With Quote
What is H?
I've done a quick sketch on sketchUp, would this be acceptable for the support?
matt_claydon
posted on 31/10/08 at 09:49 AM Reply With Quote
Originally posted by rumplitter
What is H?
It's the 'hip point'. A notional point that defines where the occupants hip would be. For IVA it's defined by putting a rectangular block of 136mm x 53mm on the seat base. i.e. the H point is 53mm up from the base and 136mm forward of the backrest.
That restraint looks fine. The manual wording strictly requires it to be 'fixed to the seat' but that's probably assuming the seat is adjustable so that the head restraint moves with the seat. In your case the seat is essentially part of the chassis so I would see no problem with the head restraint also being fixed to the chassis.
Dangle_kt
posted on 31/10/08 at 10:19 AM Reply With Quote
Is this an end to fibreglass seats?
Head restraints must be suitably padded... well there aint no padding on mine!
Dont tell me we will all need heavy cobra seats! ARG! More cost!
Got to get car done before April!!!
maartenromijn
posted on 31/10/08 at 10:49 AM Reply With Quote
I also have GRP seats. If it needs padding, I hope camping mat will do the trick??
The headrest is strong enough I hope??
Seats in car
Seats in car
BLOG: http://thunderroad-super7.blogspot.com/
Mr Whippy
posted on 31/10/08 at 11:30 AM Reply With Quote
a pad of 1 inch thick black sticky back foam should be more than enough padding on a glassfiber seat. Probably a good idea anyway as they are quite hard to bang your head off if you don't have a helmet on.
maartenromijn
posted on 31/10/08 at 11:44 AM Reply With Quote
I'll make something which is easily removable in case of wearing a helmet on the track.
l0rd
posted on 31/10/08 at 02:15 PM Reply With Quote
Stupid Qn
Should I assume that all bucket seats with 4 point harness holes are IVA approved? Would they consider it as haveing headrests?
matt_claydon
posted on 31/10/08 at 02:39 PM Reply With Quote
Originally posted by l0rd
Stupid Qn
They won't be 'IVA approved', but as long as they comply with the specifications in the manual (which i expect most will) they'll be fine.
Aftermarket seats are very unlikely to have been designed to meet the legislation, but fortunately they usually do. e.g. Some have found that the harness holes only just comply with the height requirements and require the seat padding to be squashed down a bit.
