New Topic New Reply
Author: Subject: Stitch welding?
Slimy38
posted on 20/7/15 at 05:10 PM Reply With Quote
Stitch welding?
I'm just going over some of the welds that I've missed on my travels. One of them were the double uprights on the seat back (apologies for the camera angle);
I did stitch welding to keep the distortion down, but to be honest I'm almost tempted to leave it as it is. I was also tempted to do the floor and other panels the same way, again to keep distortion to a minimum.
Can anyone see any issues with it, compared to a full weld?
[Edited on 20/7/15 by Slimy38]
theprisioner
posted on 20/7/15 at 05:21 PM Reply With Quote
Not sure what an IVA man would think of that?
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
Slimy38
posted on 20/7/15 at 06:23 PM Reply With Quote
Hmmm.... good point.
OK, I've just filled in the blanks on the uprights, it's now one (quite hot) weld. But the floor welds should be ok like that?
Rosco86
posted on 20/7/15 at 06:39 PM Reply With Quote
The double up rights if fully welded to the rest of the chassis on the ends would have 150mm of linear weld, having the best part of 600mm of weld both sides isn't going to make the chassis any stronger I don't think
My Build Thread
blakep82
posted on 20/7/15 at 07:18 PM Reply With Quote
well, my car, built as a stock car type chassis by SHP, the rear axle bracket box is stitch welded on. if its good for stock track and Rockingham oval races, i don't see an issue.
if you can fill in the gaps, you may as well really, save an ignorant testers issues with it. if done right, good penetration, it should be more than strong enough though
[Edited on 20/7/15 by blakep82]
________________________
dilley
posted on 20/7/15 at 08:33 PM Reply With Quote
That photo is more than adequate! I cannot see the weld properly although maybe slightly less wire speed?
[Edited on 20/7/15 by dilley]
40inches
posted on 20/7/15 at 08:43 PM Reply With Quote
My MK chassis has a lot of stitch welds, all the steel panels, including the floor are stitch welded, should be more than strong enough.
loggyboy
posted on 20/7/15 at 09:27 PM Reply With Quote
Stitch welding is good practice. If a weld starts to crack, it lessens the chance of it spreading along whole of a full length weld.
Mistral Motorsport
New Topic New Reply
