Scott W
| posted on 15/1/09 at 11:58 AM |
Flat/Trick Shifter
Hi All,
I'm looking to purchase a flat/trick shifter for my locoblade. Does anybody have any pictures of their shifters fitted in their cars?
I need to try and work out the best place to fit it/install it all. I'm currently having a blonde moment and hence the post!
Thanks in advance for any pics/posts you can provide.
Scott
iiyama
| posted on 15/1/09 at 12:52 PM |
Just fitted one in my car. Pretty straight forward really! If you want me to talk you through it then let me know and Ill PM my number over.
Ian
If its broke, fix it. If it aint broke, take it apart and find out how it works!
sucksqueezebangblow
| posted on 15/1/09 at 03:44 PM |
I think you probably mean the Flatshifter sensor as the rest of it can be put where theres space (within reason). Here's mine:
  Flatshifter Sensor
I am going to relocate it to the right hand side of the steering wheel so that it conforms with the conventional right UP (+) left Down (-)
mr_pr
| posted on 15/1/09 at 03:52 PM |
I thought you could swap the polarity of the sensor on the pull/push rod?
Would this not solve your 'conventional' dilemma?
My Build Progress
Scott W
| posted on 15/1/09 at 03:53 PM |
Cheers for the replies. I didn't mean the sensor as I can store that away without any issues.
I'm running a conventional stick shift setup and not paddles so I'm trying to work out the best way to put the device on to the existing
config.
Ian, I might drop you a pm when I've got it and if I get stuck.
sucksqueezebangblow
| posted on 15/1/09 at 03:56 PM |
The pull on the change lever (on the side of the engine) would still be UP when the left paddle is pulled though, as a pull on the cable is an UP on
the lever and vice versa.
sucksqueezebangblow
| posted on 15/1/09 at 03:58 PM |
config.
Ahh.. could it be you mean a power shifter type actuator?
Scott W
| posted on 15/1/09 at 04:26 PM |
Ahh man, I've really got to get some more caffeine inside me. I mis-read your earlier comment - I meant the sensor. The rest of the setup (i.e.
the black box) can be hidden away.
Off to get some coffee now......
yorkshire-engines
| posted on 15/1/09 at 06:01 PM |
Hi Scott
I have a flatshifter kit that i never fitted to the sprint
cost around £400 i think you can have for £300 if you want it
complete in box
cheers malc 07960011585
mr_pr
| posted on 15/1/09 at 07:07 PM |
Of course. I am being a half-wit today!
My Build Progress
iiyama
| posted on 15/1/09 at 08:48 PM |
OK bud, no worries!
Meeerrrk
| posted on 15/1/09 at 09:09 PM |
  Flatshifter Sensor
i was told to fit mine at the gearbox end, do you not have any issues with it at the shifter end?
yet to fit mine (i got an HM quickshifter, as used in BSB)
thanks
Mark
For Sale : 2008 Aries/Stuart Taylor Motorsport Locoblade (954 Blade)
Scott W
| posted on 15/1/09 at 11:34 PM |
quote: Originally posted by yorkshire-engines
Hi Scott
complete in box
Hi Malc,
I'll give you a call tomorrow (Friday) if that's OK?
Cheers!
Jasongray5
| posted on 15/1/09 at 11:39 PM |
how do you put your engine in neutral with one of these trick shifters then?
How hard can it be?
http://www.flickr.com/photos/33261515@N03/sets/72157611049241239/
Meeerrrk
| posted on 16/1/09 at 01:01 PM |
doesnt make any difference as far as i know
sucksqueezebangblow
| posted on 16/1/09 at 05:15 PM |
thanks
Mark
I don't know yet as the car is not yet finished but the sensor is a strain sensor so I would expect the strain to be the same at either end of
the cable (so long as the friction is low). Also the sensor is adjustable so even with a slightly higher strain at the paddle end the sensor can be
adjusted to trigger at the right point.
sucksqueezebangblow
| posted on 16/1/09 at 05:18 PM |
Same way as on a bike. Light pull from 1st (or light push from 2nd) with clutch disengaged and watch for neutral light to ignite.
Meeerrrk
| posted on 16/1/09 at 07:55 PM |
mines a strain gauge too, might fit mine at the leaver end then, will have to see when i get round to doing it (soon i hope!)
thanks for the info
thanks
Mark
