TimC
| posted on 19/7/06 at 03:40 PM |
Water Temp or Oil Temp Gauge
Greetings.
Have purchased my 5JJ R1 and am busy planning the build (waiting to move to really start.)
My engine has come with a oil temp sender already in place. My question is, do I need a water temp gauge as well as/instead of an oil temp gauge?
Comments as to why also useful and appreciated.
Ta
TC
DIY Si
| posted on 19/7/06 at 03:52 PM |
Water temp is the one you want most, but since you already have the oil gauge, get both.
Danozeman
Id go for both or at least the water temp gauge.
Dan
muzchap
| posted on 19/7/06 at 03:58 PM |
I have both and they are invaluable.
People often assume their car is warm, when the water temp gauge is - but I've noticed a big difference between water temp and oil temp!!!
Similarly the oil temp can be hotter and the water backing off again - so I'd def have both, then you have more information on what's
going on.
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
| posted on 19/7/06 at 04:06 PM |
I'm usually too busy to look at the gauges while driving! I only use them when there's a risk of problems (sitting in traffic) or a
warning light has come on.
I'd certainly fit the water temp gauge, with the oil temp as a less-important bonus.
