Wich emissions are now needed to be passed when engine is after 1995
Also how are they measured?
at idle?
and at 75% max rpm?
Tks
[Edited on 23/4/07 by tks]
Hi
See link
Noise is at 3/4 max power
HTH
Ed
thanxs mate..
Tks
if noise is at 3/4 of max RPM, this i guess comes from your submissions on the SVA application form, therefore ,
can you specify a lower top RPM, e.g. 4500 and therefore put the noise reading taken at a lower RPM?
IIRC it's not max RPM but 3/4 of RPM for max power.
ok, so could you specify max power at a lower RPM? e.g. say, my max power is at 4500 rpm?
