Author: Subject: rear diff oil and sealing it
beaver34
posted on 7/9/13 at 06:25 AM Reply With Quote
i have a english axle with a tran x plate diff in there,
whats the best oil to be using in there?
also what sealer is recommended from the diff to the axle as its weeping, and the same at the axle ends it weeping on onto the wheels
thanks!
bigfoot4616
posted on 7/9/13 at 05:45 PM Reply With Quote
i use millers CRX LS80w90 with my tran x
http://www.opieoils.co.uk/p-60255-millers-oils-crx-ls-80w-90-competition-semi-synthetic-transmission-oil.aspx
diff to casing last time i used a paper gasket but previously i've just used instant gasket, no problems with leaks.
if its getting onto your wheels it will be the bearing letting it through, been covered on here a bit.
http://www.locostbuilders.co.uk/viewthread.php?tid=167672
beaver34
posted on 8/9/13 at 08:08 AM Reply With Quote
thanks,
going to get some of that oil and also change the box oil to the miller nt stuff
the rear end i have disk brake adaptors that mount inline, after i rebuilt it leaked and didnt before with those bearings so ill take a look at them and see whats going on.
