nludkin
| posted on 13/1/07 at 05:14 PM |
How do I make this SVA proof?
I am now doing all the final tidying in readiness for SVA. The drivetrain is sorted, the wiring is finished and now I have to do the final fitting of
the bodywork.
When I posted pictures a few weeks back I was told that I need to pull the side panels in a little at the bottom to make it safe for the SVA.
However, regardless of if I pull the side panels in at the bottom, I still have sharp bits on show. How do I get around this? Am I right in assuming
that this nosecone is about 21/2 cm too narrow?
Please excuse the quality of the piccies, taken in bad lighting
Image deleted by owner
[img][/img]
[img][/img]
[img][/img]
[img][/img]
Any suggestions much appreciated. I will also be contemplating solutions over a nice few beers tonight... Mmmm beer...
[Edited on 13/1/07 by nludkin]
esn163
| posted on 13/1/07 at 05:27 PM |
Hi
similar thread here with some solutions
HTH
Ed
[Edited on 13/1/07 by esn163]
Indy Build Photos
** Build pages **
Photo Bucket Pics
flak monkey
| posted on 13/1/07 at 06:11 PM |
The nose should sit flush with the bottom of the chassis rails, or at least mine does. I have riveted my side panels to the bottom of the chassis at
the front and pulled them in as Mark has done in the other thread.
Sera
http://www.motosera.com
RazMan
| posted on 13/1/07 at 11:53 PM |
Apparently if you move your indicators further forward and out, they effectively become the front of the 'bodywork' and anything behind
them will not be tested for sharp edges by Mr SVA.
It might help as a quick fix
Raz
nludkin
| posted on 14/1/07 at 07:44 PM |
I have managed to carefully dremel off some of the "depth" from the fiberglass, which has made it sit a little more flush. However, the
nosecone definately doesn't cover the bottom chassis rail when fitted. A little investigation later and I see that the nosecone on W7DE's
are a little too narrow and not quite deep enough? It seems the dubai cars had the same setup (
http://www.locostbuilders.co.uk/viewthread.php?tid=33539). Would shrinkage due to
fiberglass curing account for this much of a gap?
I think that I will cut the side panels diagonally at the bottom to move the "sharp bits" to behind the front of the bottom wishbone. If
that makes any sense?
The indicators are already nicely forwards so hopefully none of these sharp edges will get tested anyway. *fingers crossed*
Cheers for the suggestions.
