iiyama
| posted on 6/2/09 at 04:49 PM |
Stainless tube
Need about 350mm of 60mm ID tube with a 1mm wall thickness. Anyone got an off cut or point me in a direction to get hold of some??
Ta!
If its broke, fix it. If it aint broke, take it apart and find out how it works!
Volvorsport
| posted on 6/2/09 at 04:54 PM |
youll be lucky to find it with that ID .
most tubes are 63mm /60mm OD , you then specify what gauge you want - which sounds 18/20 gauge to me .
www.dbsmotorsport.co.uk
getting dirty under a bus
iiyama
| posted on 6/2/09 at 04:58 PM |
ooops!!!
60mm OD is whats required!!
Slater
| posted on 6/2/09 at 05:06 PM |
B and Q
They sell table legs, which are steel tubes about 60mm OD.
iiyama
| posted on 6/2/09 at 05:10 PM |
With 1mm wall thickness? The ID is quite important too.......
Volvorsport
| posted on 6/2/09 at 05:27 PM |
well , it sound slike you need some 20g 60mm tube then !
whys the ID so important ?
most of the tube i can lay me hands on is 16g.
iiyama
| posted on 6/2/09 at 06:21 PM |
Modifying an exhaust with a cat in it for SVA. Have to match it onto an existing header. I have no idea of the guage as metal aint my thang. I do know
that 60mm OD with a 1mm wall thickness is whats required!
watsonpj
| posted on 6/2/09 at 07:12 PM |
have you tried talking to a stainless exhaust manufacturer there must be one near you
like
Stealth SystemUnit 3 manor ind est, manor house ave , millbrook, s,
Exhaust manufacturer ,mandrel tube bending ,custom exhausts for bikes ,cars ,trucks ,boats etc
Stainless steel specialists,stainless steel tube suppliers ,exhaust compontent supplier.
just one from a quick search I've always found these small kinds of companies really helpful
Pete
iiyama
| posted on 6/2/09 at 08:13 PM |
I know of Stealth but I wont have time to get over there unfortunatly. Was hoping to find something on the web.......
Simon
| posted on 6/2/09 at 09:16 PM |
I have some 63mm OD (approx 1mm wall) stainless and could cut 400mm of it if you want.
Won't cost you anything - unless you want to put a little in an RNLI or similar collection.
It's only a couple of mm oversize, and I'm sure you could cut and bend the end in a bit before welding
Simon
iiyama
| posted on 6/2/09 at 09:28 PM |
Hi Simon,
Your on! Thanks for the generosity.
