Afternoon
I've been looking on the threads reqarding mesh and severl time B&Q have been mentioned for about £10. I've wandered around my local
superstore a couple of times now and seen none.
What times do they sell (colour/style)? and which section is it usually in. I've given up asking as I either can't find anyone to ask or
they vaguely wave there arms round and say round here
would really like to crack on with grille etc so the front end looks a bit more finshed.
thanks
Nigel
I used a thick plastic bird mesh netting from ebay, very good and very strong and easy to use!
B&Q mesh is kept next to the metal sections, square angle etc, lots of styles, usually near the rope too
hope that helps
B&Q warehouses have more metal in stock than the smaller branches.
They have expanded mesh in steel and alu, plus some perforated sheet. It isn't cheap.
I used halfords stainless wire mesh which looks nicer, I think.
my B&Q mesh has rusted.
As far as I can see, trouble with B&Q / Homebase mesh is there's too much metal and too little hole so it would hamper the airflow.
What I was hoping for was old fluorescent tube diffuser to give egg-crate
effect but after a year of keeping an eye open, I've not seen any.
Anyone know who might sell egg-crate grill ?
Like this
[Edited on 4/9/07 by Macbeast]
Look in B&Q for a stand holding steel, aluminium and plastic bars in various sizes and shapes. You will probably find a vertical stand just to 1
side of it, containing assorted sheet metal, including expanded ali mesh.
Personally, I found their ali mesh to be thin and flimsy, and I wouldn't put any steel mesh on the front that wasn't stainless.
FWIW, I've seen nicer mesh in Halfords - and there's some woven stainless steel mesh that looks VERY attractive! Their ali mesh was around
£10 - £15 a piece, and the woven stainless was around £25 (I think - may be more). Each piece was enough to do 2, maybe 3, seven-style grilles.
HTH,
I found the mesh in the b + q whorehouse in the garden centre bit outside with fence panels and stuff
Gary
At my local warehouse it's next to the square section tube etc (same as in every B+Q I've been to who stocked it).
The steel mesh is okay but you'll need to spray it or it'll go rusty
Some plasticoat red oxide primer and plasticoat black satin did the job for me....
Your mistake is that you are looking inside the store - think outside the box and look at those trolley, lovingly crafted from mesh.
B&Q sell expanded mesh (aluminium sheet cut with tiny slices then pulled to open up the holes) - shite in my opinion and mesh for making rabit
hutches. This is quite flimsy.
There are companies mulitmesh (?) and 1 other that can sell you any mesh you like in a variety of materials - stainless steel being one of them.
troulbe is they sell in large pieces (e.g. 1 m square) so maybe a group buy?
I used 2" square steel weld-mesh. It's round bar about 1.5mm diameter welded together in a square pattern, lot's of lovely holes
It's also zinc coated so won't rust and mine was free out of a skip on a local trading estate. Just asked the guy nicely and he gave it to
me.
The steel mesh is okay but you'll need to spray it or it'll go rusty![]()
I used a BBQ grille and welded a 4mm rod surround to it with four bolts facing backwards to fix to four lugs in the nose. Didnt take as long as one
might think to weld it and tidy up with a file after.
Had to paint it of course as the chrome burned off with the welding.
Anyone know if there's an SVA issue with the diameter/radius of and size of gaps between the mesh rods in the grille?
Originally posted by The Doc
I used a BBQ grille and welded a 4mm rod surround to it with four bolts facing backwards to fix to four lugs in the nose. Didnt take as long as one might think to weld it and tidy up with a file after.
i brought some mesh from B&Q and used a fibre glass repair kit to fiberglass it to the inside of the nosecone.
just dont "somehow" get resin on the outside.... ;-(
( all off and looking great now though )
Macbeast,
If you decide what sized square hole you want and how deep you want the grille and "egg crate" look you could make it quite easily out of
sheet ally. If you cut holes halfway through each horrizontal and vertical where they intersect, turn them around and slot them into each other - you
have an egg crate. If you cut the slots to a tight fit then it will add rigidity.
You could run a piece of ally around the whole grille and use some right angled pieces riveted between this piece and the grille.
Use some paper/card as a template and build the whole thing off the car. If it's not rigid enough then you could rivet some more angles into the
egg crate between horrizontal and vertical.
hope this helps as I did a similar thing a few years ago (don't have it to show you a pikky of unfortunately)
regards
Thanks Steve, I was thinking the same.
Unfortunately I'm a measure twice, cut once and still get it wrong sort of person.
But it's worth a try
In that case try measuring twice and getting someone else to cut
