Maradona
| posted on 6/6/06 at 02:00 PM |
Aluminum Skin help!!!!
I am beginning to put the skin of aluminum to the tail of the car.
Somebody can explain to me like doing it well.
greetings from Argentina
| posted on 6/6/06 at 03:10 PM |
I can't offer the slightest bit of help or advice on the aluminium issue, but I do like your avatar
DarrenW
| posted on 6/6/06 at 03:16 PM |
My sentiments exactly. normally i would expect avatars to be kept to a minimum size but this is one that should be huuuge. How are we expected to win
the World Cup when some countries will play dirty and place such luvverliees at the touch line????????
| posted on 6/6/06 at 04:02 PM |
If the teams looked like that I'd start watching for sure. Make a template from something cheap to get the size and shape somewhere close then
take it easy and cut slots for the corners so it doesn't crease when you bend it over the rail.
Maradona
| posted on 6/6/06 at 04:53 PM |
Our best player
If you want to see our best player, look into my photo archive for Pam
| posted on 6/6/06 at 05:36 PM |
Your avatar may cause concern... please read the following thread.
Nothing to do with me - CLICKY
I got pulled today at work in the office. 1st time on an office workstation for months... ho-hum!
mark chandler
| posted on 6/6/06 at 11:13 PM |
I like your avatar, you see worse on childrens televison these days !
Anyway your question....
As ali is very soft beat it with something softer, rubber mallet etc. Personally I prefer to beat it around the tubes using a flat piece of soft
wood.
To dress it around the rear you will need to start in the middle at the bottom, hold it in place across the back then gently beat it under the
overhang going towards the ends of the car. Once you have got this started you should be able to clamp the lower edge out of site.
Where the metal goes around bends you will be trying to bend the ali in two planes, this is very hard so on the bends the overlap only wants to be
1cm. You form the vertical edge then slap the horizontal return. Where the metal is straight you can have a 2+cm return, its easy to cut the metal
wide then trim back to the tube.
For the top the same rules apply, with the bottom tube clamped securely in place(use a few rivits out of sight).
In summary
* Do not use metal hammers.
* Only bend in one plane if possible, if bending in two planes reduce the lip.
Good luck
Regards Mark
[Edited on 6/6/06 by mark chandler]
John Bonnett
| posted on 21/6/06 at 12:40 PM |
Subject: Aluminum Skin help!!!!
Mark has got it about right. Where the aluminium is going round a radius it needs to be shrunk. This is achieved using a wooden "Slapper"
or soft face hammer. Never use a metal hammer for this job as it will stretch rather than shrink. As aluminium, even 99% pure, is hammered it will
work harden so when that happens, it can be annealed to make it more malleable. To anneal, if you have oxy-acetylene, use a smokey flame and darken
the area to be annealed. Then, care is needed here, using a neutral flame heat the metal until the black disappears. This will make the aluminium much
work "Workable". Another tip is to clamp the aluminium to the metal tube so that it starts to form exactly where you want it to. It is not
too easy to clamp to a round tube especially on a bend. However it is not impossible if you use a series of G clamps and flexible plywood to provide
even pressure to hold the aluminium firmly against the steel tube. Harwood dollies can be made with the radii of curvature you need. Be patient. Metal
responds to many lightish blows rather than a few heavy ones. You may need to anneal more than once. I would recommend using 99% pure aluminium rather
than NS4 wherever shaping is needed. I can recommend the metal shaping series of videos by Ron Fournier that are sold by Frosts. Not expensive and
well worth the money.
John
John Bonnett
| posted on 21/6/06 at 12:47 PM |
Maradona, when I posted my reply, I forgot that you are in Argentina. I am sorry. Buying from Frosts may not be convenient for you but Ron Fournier
has a website www.fournierenterprises.com and you will be able to purchase videos directly from him. They really do tell you all you need to know
about metal shaping.
John
Maradona
| posted on 6/7/06 at 07:52 PM |
thanks guys
thanks guys, I really appreciate your comments, for these days we are worry about our elimination in world cup.
cheers
Maradona
