mr_pr
| posted on 4/12/08 at 11:58 AM |
Freelander End
Hello,
For those of you using a freelander diff. The only bit needed from the freelander donor shaft is the 'inner' CV with the associated
gaitors? Is there anything you take from the freelander shaft?
My Build Progress
adithorp
| posted on 4/12/08 at 12:46 PM |
Don't know about the shaft as mine were adapted and supplied with the kit.
Make shure you get the boot with it though as they're only available from L/Rover, expensive and usually factory order only. Universal ones
won't fit either.
adrian
http://jpsc.org.uk/forum/
mr_pr
| posted on 4/12/08 at 12:55 PM |
Sorry I wasn't clear. I have the Mac#1 supplied shaft, I meant the bits you add from the freelander donor, it is just the CV and boot?
My Build Progress
adithorp
| posted on 4/12/08 at 01:06 PM |
Don't know...mines a Fury.
adrian
mr_pr
| posted on 4/12/08 at 04:39 PM |
Just realised I am an idiot....
Next time instead of thinking, I will ask first!
My Build Progress
meany
| posted on 4/12/08 at 06:16 PM |
if you need anything freelander related, use "paddocks" i just have for my dads freelander....excellent comunication and service.
http://www.paddockspares.com/
Flamez
| posted on 4/12/08 at 07:06 PM |
You need;
Diff, cv joints, boots [they cost 35 each] and the tri bearing and circlip that fits on the mac drive shaft.
my blog has some pics...
hth
my build mac1motorsports
mr_pr
| posted on 4/12/08 at 08:36 PM |
I was a fool and forgot about the Trilobe... That's why I posted, I was sure it wasn't as simple (or cheap) as I was thinking. Got some
donor shafts instead though.
On a side note I read on someones blog that actually the sierra shaft inner trilobe will fit a Freelander inner CV. Can't test this though as I
don't have any freelander bits to play with yet.
My Build Progress
Flamez
| posted on 6/12/08 at 06:52 PM |
Yes they probably would but the sierra shaft is probably a different length to the Mac
