phoenix70
| posted on 14/2/09 at 02:37 PM |
Fuel rail fittings
Hi All,
looking for some ideas. here is a picture of my fuel rail, I've removed the original fuel regulator to fit an new adjustable one. I could
just flare the end of the pipe and attach a rubber pipe, but I was thinking of using braided pipe, so would need a nut or something on the end of the
rail to accept the braided hose. Any ideas welcomed.
Scott
[Edited on 14/2/09 by phoenix70]
MkII
| posted on 14/2/09 at 05:26 PM |
get a std -3 fitting tig welded or brazed to end of pipe and fit braided hose to that. m.
Phil.J
| posted on 14/2/09 at 05:45 PM |
-3 is a bit small in my opinion. I wouldn't use smaller than -6.
MkII
| posted on 14/2/09 at 05:53 PM |
phil's right -6 would be better. m.
martyn_16v
| posted on 14/2/09 at 06:21 PM |
What's the OD of that pipe?
Someone recently posted about compression fittings that give you a barbed tail to fit a hose to, would be worth a look if there's enough
clearance around the pipe.
phoenix70
| posted on 14/2/09 at 09:48 PM |
it an 8mm pipe
martyn_16v
| posted on 14/2/09 at 10:49 PM |
In that case click me. There's an eBay linky about halfway down
