Slater
| posted on 25/11/08 at 09:32 AM |
TPS sensor plug
Does anyone know which wire is which on this TPS sensor plug with respect to top, bottom and wiper. I need to know which plug pin connects to which
pin on my megajolt
Also where can I get the other half of the plug?
Carbs are ZZR1100
If it helps in the picture
Top left pin is Yellow wire
Top right pin is Black wire
Bottom pin is Blue wire
[img][/img]
whitestu
| posted on 25/11/08 at 10:38 AM |
This should help with the connections [scroll down to Martin_16v's post]:
Link
I tested/connected mine this way and it works fine.
I cut the OE plug off mine and used a cheap 3 pin multi connector.
Stu
[Edited on 25/11/08 by whitestu]
Slater
| posted on 25/11/08 at 11:18 AM |
Thanks Stu, just what I was after!
