Slater
| posted on 14/12/08 at 05:35 PM |
battery charging
My battery was flat and will not turn the engine over, I am now charging it, but just noticed none of the cells are bubbling.
Should they all be bubbling away during charging or not?
whitestu
| posted on 14/12/08 at 05:47 PM |
Yes, shouldn't be a problem.
Stu
| posted on 14/12/08 at 07:31 PM |
When the battery is fully charged they should all start to bubble --- one cell bubbling on a battery that failled to start a car would make me
suspect a problem ---- ie dead cell (aka gassing or shorted cell)
Charge the battery for a decent period, let it sit for a few hours, check the voltage with no load on should be at least 12.4 volts 12.8 is better
Fit it to the car and measure the voltage when you try and start the car. It should normally should 9 to 11 volts when cranking if it drops to 6
volts when cranking or if it drops to 6 volts then slowy rises to 8 to 9volts then you have a battey with a dead cell.
