Author: Subject: connect battery - small spark?
Slater
posted on 5/2/09 at 08:14 PM Reply With Quote
Hello
Every time I re-connect my main lead to my battery +ve, I get a very tiny spark. It does not happen if I remove the fuse for the indicators/hazard. So must be something in this circuit causing it.
Is this normal? Maybe a capacitor charging up in the flasher relay????, or does it mean something is not wired up properly.
The indicators and hazards work just fine, by the way.
Keith.
(I am about to send of the SVA application)
GeorgeM
posted on 5/2/09 at 08:18 PM Reply With Quote
always connect the +ve first, then -ve
helps to make sure nothing shorts out
(assuming -ve earth!)
GeorgeM
prawnabie
posted on 5/2/09 at 08:20 PM Reply With Quote
Hazards are always live, so I would say it is sparking because the hazard relay is pulling a small draw though the battery live?
mistergrumpy
posted on 5/2/09 at 08:28 PM Reply With Quote
What George said. Connect +ve first. I remember this after a lad in the RAF I was working with did it the other way round causing a spark which ignited the batteries venting gas and it blew up in his face. He looked like a black and white minstrel, not very nice though.
Hopefully that would stop the lead sparking or limit it to avoid this happening.
Slater
posted on 5/2/09 at 08:37 PM Reply With Quote
Good advice about connecting the +ve first. Thanks. I have been doing it the other way round for the last 3 months of the build. Doh.
speedyxjs
posted on 5/2/09 at 09:09 PM Reply With Quote
i always thought it was the other way round as if you connect the positive first, you basically become the earth. So if you are leaning on the car and accidently touch the positive, you get a bit of a shock.
posted on 5/2/09 at 09:20 PM Reply With Quote
I was given the same advice, but for a very practical reason...
If you have to use a metal tool such as a spanner to undo the battery bolts, then if you touch the chassis while undoing the -ve terminal then nothing will happen. Once the -ve is disconnected, if you touch the chassis while undoing the +ve terminal then again nothing will happen, as there's no circuit.
Now, if you start by undoing the +ve, and touch the chassis - masses of sparks, and a red-hot tool (ooer, missus!)
LBMEFM
posted on 5/2/09 at 10:27 PM Reply With Quote
I agree with speedyxjs and David, thats what I was taught as a apprentice mechanic, undo the earth terminal first.
posted on 5/2/09 at 11:23 PM Reply With Quote
Same as jump starting cars
The spark means you're drawing some current somewhere. The hazards are (as already said) constant live and can run down the battery.
One reason I fitted a battery isolator between the battery and the hazard wiring....
neilj37
posted on 6/2/09 at 08:02 AM Reply With Quote
Keith,
OFF TOPIC - How did the wheel arch protectors go. Was the sizes approx correct?
bassett
posted on 6/2/09 at 09:29 AM Reply With Quote
At college(vehicle engineering) always told on battery removal neg then pos
battery reconnection pos then neg
for the same reason as above negative removes the chance of earthing a tool to the chassis and touching the pos creating the circuit. if the neg is disconnected this cant happen
posted on 6/2/09 at 09:57 AM Reply With Quote
As mentioned removing the neg first saves that curious little spark turning into a fireball or big bang!
posted on 6/2/09 at 09:59 AM Reply With Quote
battery
I've been thinking about that the other day - this is the correct sequence.
re: the small spark; it is because you are drawing current, and as you say, by removing the fuse to the hazards you have indentified the culprit.
I have to admit I am a bit surprised that the realy is drawing current - surely it becomes only active then the hazards button is pressed?
iank
posted on 6/2/09 at 11:06 AM Reply With Quote
Put a multimeter switched to current measurement in place of the hazard fuse.
You can get a small spark from low current inductive loads (like relay coils or motors) at switch on but best to be safe.
Anonymous
Ninehigh
posted on 7/2/09 at 02:34 PM Reply With Quote
Since taking a nasty shock at a young age I'm paranoid of electricity and messing with live cables is something I only do with thick gloves, an electrically shielded spanner, rubber soles and full arm's length. I'd shut my eyes and turn my face away only I'd lose balance and electrocute my nuts or something (yeah I'm proper fearful of electricity, 240v at the age of 7 does that to ya)
A spark is normal, there's a good few things on a vehicle that draws power. My missus's car radio drained it once, and it wasn't even switched on
Macbeast
posted on 8/2/09 at 09:14 AM Reply With Quote
Whereas, a professional would never use rubber gloves, insulated tools etc as this makes them careless with a false sense of security - but you're right to treat it with respect. I'm ok with working with hot 240V wiring but boy, am I careful :-)
Ninehigh
posted on 8/2/09 at 09:40 AM Reply With Quote
Ooh no I couldn't do that, I even have to knock once before touching a metal door because of the number of static shocks I've had
