Author: Subject: Handbrake switch
Eggy
posted on 20/4/09 at 07:21 AM Reply With Quote
Handbrake switch
Has anyone got a picture of the standard Ford handbrake switch arrangement? I can't find my donor one anywhere so I think I'm going to have to get creative.....?!
[Edited on 20/4/09 by Eggy]
Ben_Copeland
posted on 20/4/09 at 07:26 AM Reply With Quote
My mk1 escort handbrake didn't have a switch, so I put one on dash...
possible option for you?
Ben
Locost Map on Google Maps
Enter Your Details Here
Eggy
posted on 20/4/09 at 07:34 AM Reply With Quote
Ben,
I thought the brake test switch (and indication light) had to be linked to the handbrake switch?
Kev.
tomgregory2000
posted on 20/4/09 at 07:40 AM Reply With Quote
no it has to be in reach of the driver
iank
posted on 20/4/09 at 07:43 AM Reply With Quote
Originally posted by Eggy
Ben,
Kev.
No requirement in the SVA for it to be on the handbrake, it can be a switch or even a simple timer circuit wired to the ignition switch. You just need a simple method of testing the bulb from the drivers seat.
Modern cars only put it on the handbrake it to prevent warrantee claims from numpties that leave the handbrake on accidentally, so they use the brake fail warning for both purposes.
[Edited on 20/4/09 by iank]
Anonymous
mr_pr
posted on 20/4/09 at 07:49 AM Reply With Quote
All true...
Mine is a push to test brake warning light and it passed!
My Build Progress
Eggy
posted on 20/4/09 at 08:01 AM Reply With Quote
Ok, thanks all!!
iank
posted on 20/4/09 at 09:03 AM Reply With Quote
Just checked and it's the same for IVA
The hydraulic system failure warning lamp must be secure,
operational, visible during daylight and darkness from the driving
position, identifiable (ie labelled in a recognised form – see diagram
1 for an example) and fitted with a “test facility” that enables its
operation to be checked from the driving position without opening
the reservoir.
Anonymous
Eggy
posted on 21/4/09 at 08:08 AM Reply With Quote
Has anyone got a circuit diagram for the Ford Master cylinder test circuit?
(And why when you do a search does it sometimes says "web page has expired" when you try to go back to the search results?)
Michael
posted on 21/4/09 at 08:33 PM Reply With Quote
I have the same web expired message, so i just refresh and they come back.
