contaminated
| posted on 11/6/09 at 02:39 PM |
EDIS to coil confusion
I've seen a post on here about this subject and specifically relating to a right way and a wrong way of wiring up the EDIS 4, but I can't
find a definitive answer. Which pins on the EDIS go to which pins on the coil plug. Some diagrams have EDIS pin 10 to Coil 1 and EDIS pin 12 to coil 3
and some have it the other way around. Anyone know which is right?
This one?
contaminated
or this one?
Slater
| posted on 11/6/09 at 03:04 PM |
top one is correct, I believe.
contaminated
| posted on 11/6/09 at 03:05 PM |
That's interesting becasuse it came from the autosports website, yet differs to the one I was actually sent with the MJ.
mcerd1
| posted on 11/6/09 at 03:15 PM |
I'll have a look at the wires later (as done by Mr Ford in 1992 )
contaminated
| posted on 11/6/09 at 03:24 PM |
Thankyou
Werner Van Loock
| posted on 11/6/09 at 05:12 PM |
I took the whole tree from a fiesta, so didn't have to worry about this, but it doesn't matter much. If it's not right, then just
swap the ignition leads (1 on 2 and 3 on 4 and vice versa)
http://www.clubstylus.be
mcerd1
| posted on 11/6/09 at 06:49 PM |
Well I think 12 joins to 3 and 10 to 1 (going by the numbers writen on the plugs themself)
but I'm red/green colour blind so what do I know
here's the pics linky 1
linky 2
(beware, they are huge pics!)
clairetoo
| posted on 11/6/09 at 07:30 PM |
As I understand it , it dosnt matter which way round they are - all thats happening is two coils are being fired alternately .
Neither the coil , the edis or the megasquirt care weather they firing 1+4 or 2+3 - it wont make the slightest bit of difference to how it runs .
Unless you already have the plug leads and they will only fit one way around........
It apparently matters on a 6 cylinder coil due to heat build-up , but mine is wrong (found out after I had spent £125 on plug leads ) , I didnt
change it and 18 months later still no problems
[Edited on 11/6/09 by clairetoo]
Its cuz I is blond , innit
Claire xx
Will weld for food......
contaminated
| posted on 11/6/09 at 08:07 PM |
Thanks all - appreciated. I agree that in the scheme of things it doesn't matter really, but I have fitted plug leads that need to be in a
certain order.
