whitestu
| posted on 23/2/08 at 01:04 PM |
Alternator Pulley
I need to get a different pulley to fit to my little Nippon alternator, so I can use it on my Zetec.
Has anyone come across a suitable pulley to do this?
Stu
Schrodinger
| posted on 23/2/08 at 01:54 PM |
http://www.locostbuilders.co.uk/viewthread.php?tid=82313
I don't know if it acheived a result.
Keith
Aviemore
Mix
| posted on 23/2/08 at 03:17 PM |
Try a visit to a scrap yard, a lot of far eastern cars use denso alternators,
I found one with a poly vee pulley, (4 vees). I intend to use this with a Halfrauds belt HB850F. The normal Zetec belt is a five vee but I'm
fairly confident that the narrower four vee will be sufficient.
I'm assuming that Denso alternator shafts are all similar so you should be able to just swap the pulleys.
[Edited on 23/2/08 by Mix]
whitestu
| posted on 23/2/08 at 07:05 PM |
I've got a Swift alternator with a 3 v pulley on it, so if I can ever seperate it from the swift alternator I'll try that.
Stu
