coyoteboy
| posted on 18/7/12 at 10:58 AM |
Interesting uprights
Spotted at the Formula Student event this year:
IMG_2105
Bluemoon
| posted on 18/7/12 at 11:08 AM |
Need a special (read expensive) bearing. Not sure of the advantages of taking the wheel centre out like that, looks cool though. Might reduce unsprung
weight but keeping the large bearing true could be non-trivial.
owelly
| posted on 18/7/12 at 11:12 AM |
Nah, half that hub and upright must have dropped off.....
http://www.ppcmag.co.uk
coyoteboy
| posted on 18/7/12 at 11:17 AM |
Indeed and mounting the brake rotor to the carbon rim also needs careful heat checks - as confirmed by the lot being covered in temperature recording
stickers at all sorts of locations!
Worked well on track though, it seems, where many failed! Seems like you'd have a larger rotational inertia with the bearing race (necessarily
quite heavy and rigid) around the outside of the rim.
phelpsa
| posted on 18/7/12 at 11:40 AM |
I would expect a good increase in corner stiffness. Which uni is it? I'd be interested to know the views of the judges!
Slater
| posted on 18/7/12 at 12:22 PM |
I wonder how the wheel is bolted onto the "hub".
RIE
| posted on 18/7/12 at 12:43 PM |
There have been a few bikes (mostly customs) that have used hubless wheels
Google Images Link
The Buell Lightning used a rim-mounted disc on the front wheel - it allows very thin spokes (obviously not hubless) as the braking force wasn't
transmitted via the spokes.
That car setup should save a fair bit of unsprung weight.
coyoteboy
| posted on 18/7/12 at 12:46 PM |
It's UAS Amberg-Weiden. I have some shots from the outside too but there's not much more to see!
I've seen a bunch of bikes done the same way, as per the link above, but I've never considered it a sensible option due to the much higher
bearing speeds and the larger mass around the outside of the rim.
[Edited on 18/7/12 by coyoteboy]
maccmike
| posted on 18/7/12 at 03:05 PM |
looks good
