omega 24 v6
| posted on 16/7/09 at 07:12 PM |
Gainsborough shower problem
Ok the font's of all knowledge who can tell me how to sort this.
My daugther has a Gainsborough 9.5 scl shower that has started pi**ing water out of the back today. So a call to Dad for help as usual.
On investigation i find that the prd in the output pipe has fired it's ball ( Suspect dodgy hose or blocked headset)
here's a pic of the article in question
So what holds the soft ball in?? Is it just jammed into the pipe so that the inner seat clamps round ( deforms the ball and grips it) the ball.??
As usual thanks in advance.
Gary
eccsmk
| posted on 16/7/09 at 07:32 PM |
you've got me on this one
but a quick call to Gainsborough in the morning should see you right
Wheels244
| posted on 16/7/09 at 09:18 PM |
Had the same fault on the same type of shower - mine was 8.5kw.
Is water in the shower overheating ? - mine was red hot - knackered thermostat.
I think the ball arrangement is an anti-scold device i.e. water is diverted down the drain tube rather than up to the shower head to prevent
scolding.
I got mine reseated but it just overheated and did it again.
I rang the Gainsborough helpline who were very helpful, they offered to send an engineer to repair the shower, but the cost was the same price as
buying a new shower unit.
So, I bought a new one and fitted it myself - piece of cake to fit.
HTH
trikerneil
| posted on 17/7/09 at 04:28 AM |
Have a look at the Shower Dr HERE.
Part No. 1 looks like the kiddie !
HTH
Neil
ACE Cafe - Just say No.
mad4x4
| posted on 17/7/09 at 07:33 AM |
Intresting .
Linky
We have the 10.5 KW Delux and it has started tripping the 30A breaker ocasionally. I have notices as well it is a bit hotter (that was my orignal
complaint - not hot enough)........ mmmm
** Why do manufacturers put in an antiscald valve it means I struggle to get a hot shower in winter as our water supply is so cold.... Shower was
right up until about may when we backed it off a bit. Girlfriend always complaining show was not hot enough, for me it was OK.
Scot's do it better in Kilts.
