INDY BIRD
| posted on 12/1/11 at 09:55 PM |
help how to keep condensation free ???
Hi all
went in the garage tonigh and it was damper than ever and its ticking me off, mnr will start to rust if this continues oh and the chrome on the new
harley will be affected,
may get a bubble for the bike but any other ideas, its a big double garage not attached so will prob cost a fortune to heat,
any ideas welcome of course in the tradition ideally locost
cheers all
dilley
| posted on 12/1/11 at 09:59 PM |
2 tonnes of salt....that will absorb it!
flak monkey
| posted on 12/1/11 at 10:02 PM |
Keep the inside temp warmer than the outside temp and allow some ventilation. Its the only way to properly stop damp.
A couple of trays of salt will help too, but if its veyr damp they'll need changing regularly.
Sera
http://www.motosera.com
INDY BIRD
only 2 tonnes ?
hows it going mr diley hope the buggy is going well?
its not really really bad, just the hole bike was covered in condensation and i have spent the evening cleaning it all off and trying to heat up tha
garage to clear it all,
so may look at vents in the windows etc if that will help??
cheers
[Edited on 12/1/11 by INDY BIRD]
big-vee-twin
| posted on 12/1/11 at 10:10 PM |
I use an oil product from Scotoiler to spray on my chromework which protects from road grime and condensation in winter, easily washes off too, works
well.
May help until you get the vent sorted out.
http://www.triangleltd.com
dilley
| posted on 12/1/11 at 10:11 PM |
Nearly done mate! been out for a drive although we are still trying to resolve the mystery running issue!
dilley
| posted on 12/1/11 at 10:12 PM |
Leave the window open on trickle?
MikeR
| posted on 12/1/11 at 10:20 PM |
Make sure the garage 'breaths'. Lots of gaps will let lots of air circulate and you'll get no damp. A sealed garage (like a sealed
loft) will get damp.
zilspeed
| posted on 12/1/11 at 10:34 PM |
Lotssssss of ventilation.
If you can't heat it, have loads of ventilation.
RazMan
| posted on 12/1/11 at 11:09 PM |
As said, ventilation is your best bet. You might try an electric oil filled radiator on really low setting - it might help a little during the wettest
months.
Raz
loggyboy
| posted on 12/1/11 at 11:20 PM |
If its condensation then it must have some temperature. Try a basic dehumidifier, parents have one in the home works well, also gives an endless
supply of ionised water, lime free, great for the wifes steam Iron if you live in a hardwater area.
jwallbank
| posted on 12/1/11 at 11:48 PM |
Ventilation has worked for me. Keeping with the locost theme I used a fan from an old desktop computer power supply - they run on 12v, quiet and are
long life - I cut a 3" hole in the wall and mounted it on the inside like an extractor fan. You can leave them running permanently. Ran
initially from a 12v battery but later used a 12v power supply from a dead rechargeable torch. Works a treat, my build which has been on the go for 5
years now and the fan is still going strong. Don't have any heating on except when I'm in there working.
RazMan
| posted on 12/1/11 at 11:51 PM |
You have HEAT in you garage??? I just have a woolly hat
eeeeeee by gum .... luxury
Raz
snapper
| posted on 13/1/11 at 06:22 AM |
Ventilation in this instance will not help, our barn was very damp yesterday and has natural ventilation through big gaps in the doors and through
cracks in the Walls.
It's been very misty lately so the air is full of water the only way to prevent this is to heat the space above the dew point which I think is
12 degrees.
For you Steve I think only a big inflated car bubble will keep it dry
I eat to survive
I drink to forget
snapper
| posted on 13/1/11 at 06:36 AM |
A bit more research shows that condensation occures closer to the current air temperature the more humid the air is so the recent problem is due to
the high humidity/mist we had yesterday.
If the material is hotter than the air, water will not condensate out of the air on to the surface, yesterday the air temp was 12 C so the car would
have to be hotter than that, most other days the difference between dew point and air temp could be as much as 20 C
No fixed temperature to aim for but in general a misty day will mean condensation, covering the car may help to reduce the issue
I eat to survive
I drink to forget
Irony
| posted on 13/1/11 at 08:16 AM |
I suffer with this problem as well. My garage is okay but I started using a butane gas heater and that just kicks out water. The only way I have
found is a proper stove burning wood or coal. Or a dehumidifier. I now have both and the garage is dry as bones. The dehumidifier is cool. It came
from B@Q and cost £80.
ed1801
| posted on 13/1/11 at 08:24 AM |
For winter on my bike I use ACF 50 spray stuff. cover the whole thing with this and then wash it off in spring. It does come off easily when washing
and protects against water and salt. My bike has now ridden through 12 salty winters - and there is no rust on it whatsoever. Shame that everything
else about it is knackered.
Bluemoon
| posted on 13/1/11 at 09:33 AM |
Ventilation simples.. I have had some issues take a look at this thread:
linky
Still there but ventilation has helped a lot in my case it's damp rising from the floor....
Dan
matt_gsxr
| posted on 13/1/11 at 10:01 AM |
You have a garage, I dream of a woolly hat
| posted on 13/1/11 at 06:18 PM |
problem also arises when the garage has filled up with moist air during the day, as it cools at night the moist air deposits the water, as it cannot
hold it all when cold - similar concept to why it rains. Also, large lumps of metal get very cold overnight and then, during the day, they get
condensed on again.
So, insulation also helps because it reduces how much the temp changes, both of the air and the items in the garage.
You need to experiment, try a 100w old style bulb on constantly, and a dehumidifier, and ventilation, and see which works for you.
snapper
| posted on 13/1/11 at 09:12 PM |
This shows the problem we have in trying to combat condensation in a garage
I eat to survive
I drink to forget
