As my car is in a winter strip down, and good access to the tunnel,
I may fit a prop catcher, but where ?
front middle or back
I was planning on the middle, as best access for welding
steve
I have 2, one at front and one at back
I only fitted one and decided on the front.
I always have mine at the front.
If the UJ's are the same the one at the front will always fail first because thats where power is applied first.
Front is probably the most critical but I'd want and have one at both ends. The rear one is a bit bigger to allow for suspension movement. Front one is a fair bit tighter.
If the front UJ lets go, the prop will flail until the car comes to a halt (whilst beating the hell out of the leg you need to stop the car), if the rear goes the prop will flail until you put the clutch in. If you can only fit one, fit it at the front.
Why all the concern over prop catchers? Is there a lot of evidence that props fail and if so, why? Poor design , poor construction, UJ's not replaced when needed etc. Will I regret asking?
Thanks for the answers, front seem to be the preferred,
I will revise my plans
steve
I've seen reports of some breaking and there tends not to be much between your leg and the prop in a kit compared to a commercial vehicle. Probably a slim chance of it happening but worth protecting against. I want a roll bar and I reckon my prop stands a better chance of letting go than I do of rolling the car!
A number of early Sierra Robin Hood propshafts broke as they had used the original Sierra rubber doughnut. In the Sierra this acts as a damper, not a
UJ - the prop run is almost dead straight and there diff movement at the back end (unlike a live axle). The RH prop run was not straight and the
donut ended up acting like a UJ and promptly failed.
I saw the results of a failure where the prop had beaten the square tunnel out into a circular shape, at about hip position. Considering that was in
a steel monocoque tunnel, the damage it could create ally tunnel sides would be alarming.
Not sure what the likelihood of a proper propshaft breaking is - maybe it is down to the quality of fabrication, specially where it has been made by
shortening a longer donor prop - a sort of 'cut-and-shut'. That said, you are sitting very close to it.
I see the rationale for front rather than rear but I would have thought that on a IRS car there would be zero movement at the diff end and
'some' movement at the front end, as the engine moves on its rubber mounts? But then I haven't seen one of these 'prop
catchers' so don't how they fit or what the tolerances are.
I have yet to fit one, however it's on the list, when I crashed my kit the engine lurched forward and the front spline on the prop dropped out of
the gearbox. The car carried on rolling and the inside of the tunnel was damaged where the prop had bashed into it. Not quite the same as full chat
but still a handy reminder to look after ones legs.
I have since fitted a tie bar to stop the engine moving too far on it's mounts, and will fit a prop catcher over winter
2 IMO -
Unless you have one centrally that is a good fit and will stop the prop from reaching the tunnel.
1 at 1 end is silly, just cutting the chances of it working by 50%
[Edited on 20-11-15 by loggyboy]
If the prop fails at the front it is possible for the prop on some cars to dig into the road and pole vault the car.
I saw a chapter of Mithbusters where the had a very hard time trying to accomplish that.
IIRC.
No one likes buying a fire extinguisher, and 99.999% they're never used, but........
quote:^^ as the others have said its not that common a fail if you've got a well made and well maintained propshaft...
) Way back in the early 1990's my Caterham started to make a loud banging noise from the tunnel when taking LH bends with some enthusiasm, fine on
RH bends. The instant cure was to drive slower but why have a Caterham and drive slowly. Carefully inspected the car but could find no evidence of the
issue until I took the seats and tunnel carpet out. The aluminium tunnel at the side of my left thigh was well battered but since the car had a full
floor covering the underside of the transmission tunnel it was not visible during a normal check. Once the tunnel cover and gearlever were removed the
problem was obvious, the gearbox mount rubber had failed probably due to oil contamination. Mount replaced and a breather tube brazed to the gearbox
lid with a pipe to the catch tank and no more issues.
But seeing the damage that was caused by a prop that was still intact focused my mind for a few weeks.
