Author: Subject: no oil presure
jpindy3
posted on 20/6/09 at 03:04 PM Reply With Quote
no oil presure
right im fitting my mj v3,
and to begin with i had the trigger wheel in the wrong place causing a backfire,it started to run on 3 cyl,i have got it running fine now through the eids4 limp home mode
my guage neadle lifts a little and just stays at 0,i have looked at the wiring and that seems fine
now would that cause any problems with oil presure??
i have a racetec oil presher gauge 0-8 bar,
any ideas why i have lost my oil presure
[Edited on 20/6/09 by jpindy3]
blakep82
posted on 20/6/09 at 03:09 PM Reply With Quote
it'll be nothing to do with MJ, so rule that out. unless you've somehow managed to earth the gauge sender, which is unlikely
any other changes made at all?
[Edited on 20/6/09 by blakep82]
________________________
jpindy3
posted on 20/6/09 at 03:24 PM Reply With Quote
no other changes,
if the cam cover isnt selled propally would that be it,
the cam cover wasnt bolted down
i have just taken the plugs out and turned it over to see if any oil would come out of the spray bar and none did i turned it over for about 30-40sec
help
iank
posted on 20/6/09 at 03:25 PM Reply With Quote
You haven't removed the distributor have you? On the pinto it also drives the oil pump!!!
Other than that knocked wire off the pressure sensor (or burnt it out by shorting it while working on the loom)? or if it's capillary you kinked the tube while working on the engine?
Can't think of anything else directly related to working on a MJ installation.
Anonymous
jpindy3
posted on 20/6/09 at 04:01 PM Reply With Quote
right thats it then i have removed the dizzy so il put it back and turn it over by hand
iank
posted on 20/6/09 at 04:13 PM Reply With Quote
Yes that will work.
Longer term a tidier solution is to chop down the dizzy and mount it using a bearing (some lathe work required).
See the pictures here
http://www.locostbuilders.co.uk/viewthread.php?tid=115813
or retaining the bush rather than using a bearing see DaveFJ's info here
http://www.locostbuilders.co.uk/viewthread.php?tid=72118
Anonymous
