Author: Subject: throttle return spring
cd.thomson
posted on 11/3/10 at 11:12 AM Reply With Quote
I got my throttle pedal hooked up last night and I'm not 100% confident with its action as it seems a bit sluggish on return with very little resistive feedback on the pedal. At the minute I'm simply using the spring on the carbs.
Would a return spring on the throttle represent a good option? Where could I get one from?
Craig
whitestu
posted on 11/3/10 at 11:19 AM Reply With Quote
If you are using bike carbs you will probably need and extra spring. I used one that came from a cheapo spring pack - Halfrods and Screwfix sell them I think.
Just chose one the right length and made a bracket to hold it in the right place to connect to the cable quadrant on the carbs.
Stu
pewe
Return spring on the throttle pedal is a good idea.
Most good local accessory shops will keep those.
Alt try Rally Design, Merlin Motorsport or BG Motorsport. HTH. Cheers. Pewe
cd.thomson
posted on 11/3/10 at 11:23 AM Reply With Quote
cheers
Craig
couch22k
posted on 11/3/10 at 11:27 AM Reply With Quote
I've hooked the bootom of the pedel to the bulk head with a spring.
I'll try to get a pic posted later.
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 11/3/10 at 11:51 AM Reply With Quote
This sounds like a good option to me, also make sure the cable is running smoothly in its 'jacket'.
Also perhaps a stiffer spring in place of the one you have?
i've bike carbs on mine and not really had a problem but hopefully that helps
blakep82
posted on 11/3/10 at 11:59 AM Reply With Quote
i had 2 springs came with my pedal. they're not particularly strong, but them and the carb springs give a good feel to the pedal and a good quick return.
i don't know if they anything special, but the springs that cam with mine are a spring 'body' with the end hooks floating inside so they spin round. i've seen others exactly the same sold as throttle springs, so i don;t know if theres any particular reason for going with that type
________________________
steve m
posted on 11/3/10 at 12:03 PM Reply With Quote
Toyota have some on back order !!
a4gom
posted on 11/3/10 at 12:19 PM Reply With Quote
You need to check how the cable is fixed at each end if you are using a spring on the pedal as this may mean you inadvertantly disconnect the cable at one or both ends or end up with loose cable if / when the pedal returns to its stop quicker than the throttle spring takes up the slack.
Perfect planning prevents pi$$ poor performance!
TimC
posted on 11/3/10 at 12:24 PM Reply With Quote
Ratsport Linky-dink
blakep82
posted on 11/3/10 at 12:33 PM Reply With Quote
er, not particularly cheap...
cd.thomson
posted on 11/3/10 at 12:36 PM Reply With Quote
got it a bit cheaper
Craig
Slater
posted on 11/3/10 at 12:46 PM Reply With Quote
This is how I did it, very cheap. It works just fine. I have some springs left over from a selection pack, let me know if you want one.
[img][/img]
Stott
posted on 11/3/10 at 07:42 PM Reply With Quote
genius, hahahahahaha
