Slater
| posted on 25/3/10 at 09:43 AM |
type 9 - selecting reverse problem
Hello, I am having increasing trouble selecting reverse on my type 9 gearbox. It will select reverse eventually but only after a good bit of stirring.
The only modification I made was to cut 3" off the top of the gear lever.
Any advice on how to cure this?
dan8400
| posted on 25/3/10 at 09:49 AM |
Does your clutch cable need tweeking? Maybe if it's not disengaging all the way you might not get reverse. Is it crunching alot? Or you
can't engage it?
Dan
Hey - That's Journey!!!
deezee
| posted on 25/3/10 at 09:50 AM |
Is it clearing the detent ok, but not going into gear? Or is it just having trouble engaging the gear once selected?
Slater
| posted on 25/3/10 at 10:12 AM |
It's not crunching, the lever just won't move over far enough to the reverese position. All the other gears will select fine.
Thanks for replies by the way....
dan8400
| posted on 25/3/10 at 10:15 AM |
Has the reverse stopper come loose inside the selector housing? I had to remove mine to fit the remote. Wasn't that well held in.
Other than that i'm all out of ideas. Maybe someone who knows more about it can help
Dan
iscmatt
| posted on 25/3/10 at 10:16 AM |
you are pushing down to select reverse?
(turn it off and on again sort of advice!)
matt_gsxr
| posted on 25/3/10 at 10:21 AM |
The BEC experience.
stevec
| posted on 25/3/10 at 10:22 AM |
Has the nylon clip at the bottom of the stick on the selector rod come loose/rotated/fell off?
jabbahutt
| posted on 25/3/10 at 10:34 AM |
I had that problem, turned out as mentioned above that the cable just needed adjusting where it connects to the gearbox due to the new cable probably
stretching slightly
Bluemoon
| posted on 25/3/10 at 12:54 PM |
I had same problem plastic nylon thingy was warn out (as per above)...
Dan
[Edited on 25/3/10 by Bluemoon]
Slater
| posted on 25/3/10 at 12:56 PM |
OK thanks gents, I will check the cable and nylon thingy too.
bob tatt
| posted on 25/3/10 at 06:55 PM |
as above it will be the plastic bit on the end of the stick, had the same problem on my last build. i got a newone from ford dont know if you still
can.
