AdrianH
| posted on 12/6/11 at 10:03 AM |
What to do with this hole Silvertop?
I believe thi was the vent to a flame trap etc. in the original escort.
I have seen blanking plates for it but wonder if it would be best to fit a plate with a vent hole or tube to go to an oil catch tank.
So wondering what other have done?
Adrian
[Edited on 12-6-11 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
Myke 2463
| posted on 12/6/11 at 10:21 AM |
Normally breather to the inlet manifold, mine has a pipe to the catch tank.
Be Lucky Mike.
JAMSTER
| posted on 12/6/11 at 10:23 AM |
i think turbo engines use a core plug. not sure what you do on non turbo i've used the box that it came with in to a catch tank
lsdweb
| posted on 12/6/11 at 10:36 AM |
If you fit just an outlet, you risk the crank throwing a lot of oil up there (don't ask how I know!).
When I had mine I spoke to Dunnells who recommended I just blanked it up. So I did and had no problems whatsoever.
Regards
Wyn
madteg
| posted on 12/6/11 at 11:06 AM |
Fit core plug cannot remember what size, got mine of ebay for turbo conversions. You will find that you get extra gases from the camshaft breather now
so pipe to a catch tank with breather/filter.
I just left the original oil breather on there and plumbed the outlet under the car to air...
austin man
| posted on 12/6/11 at 01:24 PM |
plumbed mine to a catch tank with breather. It was designed with it so I personall would think it needs it, it would reduce crankcase pressure surely
Slater
| posted on 12/6/11 at 01:49 PM |
I blanked mine off, no problems at all.
ETA - See similar thread from when I asked the same question:
linker to thread
[Edited on 12/6/11 by Slater]
