Author: Subject: Tube beading tool has anyone made one
PHULL
posted on 19/1/09 at 02:44 AM Reply With Quote
I need a tool to put a bead on some thin wall aluminium radiator tube, rather than buying one has anyone got any ideas how to make homemade one?
nitram38
posted on 19/1/09 at 03:45 AM Reply With Quote
Do a search. There is a B & Q tool, like a set of pliers that will put the bead on and only £13.
PHULL
posted on 19/1/09 at 04:56 AM Reply With Quote
tried searching, but couldn't find anything
tul214
posted on 19/1/09 at 05:39 AM Reply With Quote
This one?
http://www.locostbuilders.co.uk/viewthread.php?tid=98934
1.6 Raw Super6 sold
nitram38
posted on 19/1/09 at 05:51 AM Reply With Quote
I just searched "pipe beading" and came up with this
daviep
posted on 19/1/09 at 08:05 AM Reply With Quote
I made mine from a hydraulic quick disconnect (snap-tite h series) like this:
I removed the locking collar to expose the ring of ball bearings, removed all the internals and then made a cone shaped wedge to push the balls out.
The final result
beaded pipe
beaded pipe
[Edited on 19/1/09 by daviep]
PHULL
posted on 19/1/09 at 08:21 AM Reply With Quote
The final result
beaded pipe
beaded pipe
I went for "tube beading"
then just "beading" in both the tools section and the whole forum. but cheers for your help
Slater
posted on 19/1/09 at 10:07 AM Reply With Quote
I used a pair of mole grips, a ball bearing, a nut and some insulation tape. Very locost, free infact.
Tape the nut on to one jaw of the mole grips and the ball bearing to the other. Put the "ball" jaw into the end of the ali pipe and squeeze, repeat around the circumference.
You probably have all the items required in your garage, but you might have to experiment with the nut/ball size.
Worked for me.
mangogrooveworkshop
posted on 19/1/09 at 10:26 AM Reply With Quote
Look at my you tube video that will explain how you do it.
You get some oyster pliers from BLOCK & QUALE FOR ABOUT £11.99
Would link but you tube is blocked on this net connection
Search for user mangogrooveworkshoplink to video
link to tool
[Edited on 19-1-09 by mangogrooveworkshop]
