Author: Subject: Dashboard covering
speedyxjs
posted on 15/6/09 at 06:46 PM Reply With Quote
Dashboard covering
What have you guys (and girls) used for covering the dashboard?
RoadkillUK
posted on 15/6/09 at 06:50 PM Reply With Quote
Pre-SVA we had vinyl on foam.
Post-SVA it's a CF lookalike GRP.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
chris_smith
posted on 15/6/09 at 06:51 PM Reply With Quote
i used black leatherette onto laminate floor underlay foam then plyboard
cheers
chris
speedyxjs
posted on 15/6/09 at 06:56 PM Reply With Quote
Am i right in thinking if i have a padded dashboard, i dont need the bottom of the dash radiused?
matt.c
posted on 15/6/09 at 06:57 PM Reply With Quote
Do yourself a favor and just get some fake carbon sheet. You will end up getting some in the long run!
Stuart_B
i used, plywood and camping mat foam and black vinly.
stuart
speedyxjs
posted on 15/6/09 at 07:02 PM Reply With Quote
Im not a big fan of cf. Think it looks a bit weird.
chris_smith
posted on 15/6/09 at 07:04 PM Reply With Quote
you still need the bottom radiused at 19mm whether its padded or not, i used 38mm drain pipe
speedyxjs
posted on 15/6/09 at 07:14 PM Reply With Quote
How did you fix it on?
chris_smith
posted on 15/6/09 at 07:37 PM Reply With Quote
cut it down its lengthpushed onto the ply then screw every couple of inch then foam over pulled tight with vinyl/leatherette, then stapled to the ply
speedyxjs
posted on 15/6/09 at 07:50 PM Reply With Quote
Great cheers
posted on 15/6/09 at 08:17 PM Reply With Quote
Yup. Plywood with thin foam and vinyl on top for me..... (and a bolt on bit on the bottom of the dash which passed the radius rule but fell off shortly after)...
stevegough
posted on 15/6/09 at 08:35 PM Reply With Quote
I am completely stunned by the amazing engineering I keep seeing evidence of by many of the members on this site, which brings me to the point in question.......
If you guys are so amazingly great at fixing things, why, oh why do I keep seeing comments like the above where items fixed fall off ? - and is it a coincidence these items all seem to fall off just after the SVA test has been completed? It really is a complete enigma to me !!
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
tomprescott
posted on 15/6/09 at 08:36 PM Reply With Quote
I don't mind real carbon fibre - but carbon fibre effect stuff is too chavtacular for me!
adithorp
posted on 15/6/09 at 08:38 PM Reply With Quote
19mm radius is for rigid dash. Padded is 10mm I think but it depends on the padding. Might have changed for IVA. Check the manual.
http://jpsc.org.uk/forum/
imp paul
posted on 15/6/09 at 09:01 PM Reply With Quote
you could flock your dash it looks very cool like in wrc cars eg mitsys worth a look http://www.getflocked.webeden.co.uk/#/gallery/4527762201 />
[Edited on 15/6/09 by imp paul]
RoadkillUK
posted on 15/6/09 at 09:43 PM Reply With Quote
We also used plywood or was it MDF? Either way, we glued another thin piece of ply on the back at the bottom and used a router to radius it, then camping mat then vinyl.
Roadkill - Lee
www.bradford7.co.uk
MkII
posted on 15/6/09 at 09:49 PM Reply With Quote
I had my striker dash flocked
Cheffy
posted on 16/6/09 at 08:33 AM Reply With Quote
Morning Chaps,
This is from the IVA manual:-
The instrument panel lower edge within the “specified zone” must have a radius of curvature not less than 19mm or 5mm and covered with a non-rigid material. Except where an adaptation for a disabled person makes it impossible to comply. (see note 7)
Hope that helps.
Mart.
Farts are like Rock'n'Roll. You love your own but you hate everybody else's. Lemmy, Motorhead.
piran
posted on 1/7/09 at 08:08 AM Reply With Quote
we used camping mat and vinyl on 9mm ply, we stuck a stuck a strip of the camping mat across the bottom and that was fine for SVA.
