Author: Subject: Bike Carb Fuelling Setup
locosaki
posted on 6/11/09 at 03:08 PM Reply With Quote
Hi all,
I've just finished fitting ZZR1100 carbs to my Vauxhall redtop,Does anyone have a rough idea in how I should be setting these up ?
There is no one up my neck of the woods(Fife Area) that do these conversions so I'll have to get this correct on my own !
I assume to get the fuelling set up any where near correct I'm going to have to buy a wideband Lamda sensor,Is this correct ?
Thanks in advance
r1_pete
posted on 6/11/09 at 03:22 PM Reply With Quote
On my Zetec Bogg Brothers drilled the main jest to 1.7mm, and advised 3.5 turns out on the pilot screws.
You'll need a vacuum gauge to balance them, assuming the one with the throttle stop is number 3, set number 4 to match it, followed by 2 then 1.
will121
posted on 6/11/09 at 03:58 PM Reply With Quote
ive seen a section out of a magazine for fitting to your engine somewhere this is all i can find at mo bet will try have another look when home
links
locosaki
posted on 6/11/09 at 04:03 PM Reply With Quote
Cheers guys,
The link is excellent,There's pull it there from bogg bros on carb set up.
arrow-engineering
posted on 6/11/09 at 08:01 PM Reply With Quote
set up
a wide band lambda will be useful if you plan to jet the car yourself, it will give you an accurate readout of if the engine is running rich or lean.
Russell
posted on 6/11/09 at 08:58 PM Reply With Quote
This site is handy for the theory side of setting up bike carbs:
http://www.iwt.com.au/mikunicarb.htm
I'm a bilingual illiterate. I can't read in two languages.
